LM32 4.6 toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Mon Apr 4 17:38:11 UTC 2011
On 04/04/2011 07:18 PM, Sebastien Bourdeauducq wrote:
> Hi,
> to my knowledge, the LM32 GCC build failure in 4.6 is only related to
> the C++ compiler, which was broken anyway (generating incorrect code) in
> 4.5.x. Can we simply disable it and upgrade the toolchain RPMs to 4.6
> with the C compiler alone?
Nope. Bootstrapping lm32-rtems4.11-gcc-4.6.0 also segfaults when
enabling only c.
c.f. http://gcc.gnu.org/bugzilla/show_bug.cgi?id=48230
This was against gcc-4.6.0-RC-20110321 w/ cxx enabled,
but the error is the same with gcc-4.6.0 (final) and cxx disabled:
/users/rtems/rpmbuild/BUILD/rtems-4.11-lm32-rtems4.11-gcc-4.6.0/build/./gcc/xgcc
-B/users/rtems/rpmbuild/BUILD/rtems-4.11-lm32-rtems4.11-gcc-4.6.0/build/./gcc/
-nostdinc
-B/users/rtems/rpmbuild/BUILD/rtems-4.11-lm32-rtems4.11-gcc-4.6.0/build/lm32-rtems4.11/newlib/
-isystem
/users/rtems/rpmbuild/BUILD/rtems-4.11-lm32-rtems4.11-gcc-4.6.0/build/lm32-rtems4.11/newlib/targ-include
-isystem
/users/rtems/rpmbuild/BUILD/rtems-4.11-lm32-rtems4.11-gcc-4.6.0/gcc-4.6.0/newlib/libc/include
-B/opt/rtems-4.11/lm32-rtems4.11/bin/
-B/opt/rtems-4.11/lm32-rtems4.11/lib/ -isystem
/opt/rtems-4.11/lm32-rtems4.11/include -isystem
/opt/rtems-4.11/lm32-rtems4.11/sys-include    -g -O2
-mbarrel-shift-enabled -O2
-I../../gcc-4.6.0/gcc/../newlib/libc/sys/rtems/include -g -O2 -DIN_GCC
-DCROSS_DIRECTORY_STRUCTURE  -W -Wall -Wwrite-strings -Wcast-qual
-Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition
-isystem ./include   -g -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2
-D__GCC_FLOAT_NOT_NEEDED -fno-stack-protector -Dinhibit_libc -G 0
-msign-extend-enabled -I. -I. -I../../.././gcc
-I../../../../gcc-4.6.0/libgcc -I../../../../gcc-4.6.0/libgcc/.
-I../../../../gcc-4.6.0/libgcc/../gcc
-I../../../../gcc-4.6.0/libgcc/../include    -o _ffsdi2.o -MT _ffsdi2.o
-MD -MP -MF _ffsdi2.dep -DL_ffsdi2 -c
../../../../gcc-4.6.0/libgcc/../gcc/libgcc2.c \
xgcc: internal compiler error: Segmentation fault (program cc1)
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make[4]: *** [_ffssi2.o] Error 4
Ralf
