Fatal errors
Peer Stritzinger peerst at gmail.com
Fri Apr 8 13:34:31 UTC 2011
Hi,
I want to pick out this old posting from Sebastian, and try to get the
discussion about this going this time.
Presently I'm implementing the handling and reporting of fatal errors
in an RTEMS application I'm building.
Since I can't use the console (because there is none when the hardware
is in the field) bot other means of storing/communicating the error I
just found out about all the same points that Sebastian mentions.
Getting accurate errors from devices deployed in the field is very
important and RTEMS is not very helpful with this at the moment.
Cheers
-- Peer
On Wed, Aug 11, 2010 at 3:47 PM, Sebastian Huber
> Hi,
> I want to discuss some issues with fatal errors in RTEMS.  A fatal error is
> something that renders the system unusable.  For example if you provide a works
> space that is not big enough to contain all configured objects it makes no
> sense to continue execution.  Fatal errors may happen due to:
> 1. Configuration bugs
> 2. Classic bugs inside the system caused even with valid user input
> 3. Invalid user input (lack of documentation etc.)
> There are several entry points to the ultimate fatal error handler (void
> _CPU_Fatal_halt(something the_error)):
> 1. void _Internal_error_Occurred(
>     Internal_errors_Source the_source,
>     bool is_internal,
>     Internal_errors_t the_error
> 2. void rtems_fatal_error_occurred(
>     uint32_t the_error
> 3. assert()
> There are also some error functions that end up in _exit() which does some
> clean up and initiates a context switch to the boot code:
> 1. exit()
> 2. abort()
> 3. std::terminate() (C++)
> 4. void rtems_panic(
>     const char *printf_format,
> 5. int rtems_error(
>     rtems_error_code_t error_flag,
> The actions performed by _exit() are quite complex.  You need a fully
> functional system to do this.  The rtems_panic() and rtems_error() functions
> are very heavy weight due to dependencies on fprintf().  Also _exit() may fail
> to shut down the system due to IO driver flaws.
> Some notes to the _CPU_Fatal_halt() class functions:
> 1. The the_source and the_error values should be enough to identify the exact
> error source provided you have the source code and an ELF-file with symbol
> information.
> 2. The is_internal parameter is superfluous.  We can use the_source for this.
> 3. We loose information if we call _CPU_Fatal_halt() only with the_error
> parameter.  This value is ambiguous without the_source.
> 4. assert() ends up in rtems_fatal_error_occurred(0).  Here we loose all
> information about the error and rely to much on printk().
> 5. Currently we have these sources:
> typedef enum {
>  INTERNAL_ERROR_CORE,
>  INTERNAL_ERROR_RTEMS_API,
>  INTERNAL_ERROR_POSIX_API
> } Internal_errors_Source;
> This is not enough.  We should add at least a source for the BSP, the
> application and triggered by assert().
> 6. We should change the type of the_error to be at least 32-bit wide and
> capable to hold a pointer value.  This can be used by assert() to store the
> failed expression string pointer.
> 7. The RTEMS source code should be reviewed to meet 1.
> 8. A call to _Internal_error_Occurred() should work at any time.  To achieve
> this we have to statically initialize _User_extensions_List as an empty list.
> It would be nice if you can add some comments about this.
> Have a nice day!
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> E-Mail  : sebastian.huber at embedded-brains.de
> PGP     : Public key available on request.
> rtems-users mailing list
> rtems-users at rtems.org
