Ethernet Layer communications
Daron Chabot
daron.chabot at gmail.com
Thu Apr 14 21:21:41 UTC 2011
On Thu, Apr 14, 2011 at 5:16 PM, Brett Swimley <brett.swimley at aedbozeman.com
> wrote:
> Thanks Daron,
> I had found this reference, and it appears that libpcap uses this API, so I
> will continue looking. I'm hoping that the RTEMS stack does support bpf.
I had a brief grep through the source tree and noted that there were only 3
NIC drivers that had the bpf_mtap( ) interface (all ported from FreeBSD!):
dchabot at dev32new--> git grep -n bpf c/src/libchip/network
c/src/libchip/network/i82586.c:1280: if (sc->arpcom.ac_if.if_bpf != 0)
c/src/libchip/network/i82586.c:1282: bpf_mtap(sc->arpcom.ac_if.if_bpf,
m);
c/src/libchip/network/i82586.c:1378: if (ifp->if_bpf)
c/src/libchip/network/i82586.c:1379: bpf_mtap(ifp->if_bpf, m0);
c/src/libchip/network/if_dc.c:159:#include <net/bpf.h>
c/src/libchip/network/if_dc.c:3372: if (ifp->if_bpf)
c/src/libchip/network/if_dc.c:3373: bpf_mtap(ifp,
m_head);
c/src/libchip/network/if_fxp.c:87:#include <net/bpf.h>
c/src/libchip/network/if_fxp.c:1262: * Pass packet to bpf if
there i
c/src/libchip/network/if_fxp.c:1264: if (ifp->if_bpf)
c/src/libchip/network/if_fxp.c:1265: bpf_mtap(ifp,
mb_head);
But, on further inspection, the bpf_mtaps( ) were "#if 0"'d out of
commission.
Then there's the issue of creating /dev/bpfX device nodes...
I would be surprised if someone out there doesn't have something already,
perhaps created to support message passing between nodes of a distributed,
multi-processing system?
I'm looking at you Till... ;-)
-- dc
> Brett
> On Thu, Apr 14, 2011 at 2:30 PM, Daron Chabot <daron.chabot at gmail.com>wrote:
>> Hi Brett,
>> I have not looked into this in much detail, but since RTEMS' network stack
>> is ported from FreeBSD, you may be able to use the Berkley Packet Filter
>> (bpf) API for this.
>> -- dc
URL: <http://lists.rtems.org/pipermail/users/attachments/20110414/9cb44da9/attachment.html>
