Strange problem with newlib strstr function and rtems 4.10 on coldfire
Paul Whitfield paulw at omnitronics.com.au
Mon Apr 18 08:16:22 UTC 2011
On 18/04/2011 2:53 PM, Ralf Corsepius wrote:
> On 04/18/2011 06:28 AM, Paul Whitfield wrote:
>> On 18/04/2011 10:51 AM, Paul Whitfield wrote:
>> I have checked the newlib CVS and the version of strstr.c and
>> str-two-way.h in RTEMS4-10 are update to date with the most current
>> version.
>> One last note: Recompiling the strstr.c / str-two-way.h code newlib code
>> on the PC the code works correctly with the optimised version.
> Are you trying to express you can reproduce your issue on PC?
> I just tried, but I can't reproduce it.
> Ralf
Sorry I was unclear. No I can NOT reproduce the problem on the PC.
I have done some more investigation ...
PLEASE NOTE:
I did NOT build gcc / newlib from source.
I am using the pre-compiled version from
ftp://ftp.rtems.org//pub/rtems/mingw32/4.10/
and it is behaving the same way as the code I am compiling here.
I did some searching and found a similar symptom to what I have
been seeing.
It seems to be the strstr code is breaking because it expects the value
of the macro SIZE_MAX to be the maximum value of a size_t variable
however it appears that using the standard RTEMS include files,
SIZE_MAX is actually 32.
If I follow the same includes as in strstr.c and str-two-way.h
then SIZE_MAX is 32.
ie. If I compile the following
#include <limits.h>
#include <stdint.h>
#if ( SIZE_MAX == 32 )
#error "SIZE MAX is 32"
#endif
With the rtems compiler (m68k-rtems4.10-gcc) I get
#error "SIZE MAX is 32" message.
If I "hack" the strstr.c/ str-two-way.h files, to force
SIZE_MAX to be UINT_MAX then the code works correctly.
My test case works.
Is something broken about how newlib has been built?
Regards
Paul Whitfield
Software Engineer
27 Sarich Court, Osborne Park
Perth WA 6017
P:  +61 8 9445 2633
F:  +61 8 9445 1687
I: www.omnitronics.com.au <http://www.omnitronics.com.au>
Message  protected by MailGuard: e-mail anti-virus, anti-spam and content filtering.http://www.mailguard.com.au/mg
