Ethernet Layer communications
Brett Swimley
brett.swimley at aedbozeman.com
Thu Apr 14 21:16:04 UTC 2011
Thanks Daron,
I had found this reference, and it appears that libpcap uses this API, so I
will continue looking. I'm hoping that the RTEMS stack does support bpf.
Brett
On Thu, Apr 14, 2011 at 2:30 PM, Daron Chabot <daron.chabot at gmail.com>wrote:
> Hi Brett,
> I have not looked into this in much detail, but since RTEMS' network stack
> is ported from FreeBSD, you may be able to use the Berkley Packet Filter
> (bpf) API for this.
> -- dc
URL: <http://lists.rtems.org/pipermail/users/attachments/20110414/13b81361/attachment-0001.html>
