RTEMS evolution was .. Re: bits/wordsize.h
Chris Johns
chrisj at rtems.org
Mon Apr 18 23:43:59 UTC 2011
On 19/04/11 2:18 AM, Joel Sherrill wrote:
> + Embedded Brains has a USB stack port and TCP/IP stack update
> that requires some more work to be merged. Beyond the obvious benefits
> of having a USB and updated TCP/IP stack, this will address a number of
> issues including IPV6. But this really needs some sponsorship to get
> merged cleanly.
Just to expand this item because it is important. The blocker with this
code is the BSD bus space API. The USB and networking drivers use the
bus space API to access devices. The port for the USB stack which is
available as a patch in PR 1601 contains a version to allow it to run on
a specific target. We need the bus space API implemented with in the
score of RTEMS and an adaption layer to the specific BSD bus calls used.
This is a complex and critical task because of performance and the
various number of architectures we need to support with all the DMA and
cache variations they have. The objective is to provide a framework that
allows us an easy upgrade path in the future for these BSD components we
use.
Embedded Brains has done a large part of the task and the work is first
class how-ever we need this merged to stop it rotting. If you have any
interesting in seeing this happen please contact Joel.
