bsp_delay.... Question
Andrei Chichak groups at chichak.ca
Mon Apr 25 20:17:47 UTC 2011
Alright, I'm going to have to advocate for the little guy.
At 16Mhz, I would have, at best, 16 instructions at a microsecond.
A millisecond based delay would be doable using a timer. I could see crafting a loop for a microsecond delay, but nanosecond would be a summer fantasy.
Andrei
On 2011-April-25, at 12:49 PM, Joel Sherrill wrote:
> On 04/25/2011 11:49 AM, Thomas Doerfler wrote:
>> Joel,
>> without looking into the existing implementations: I would prefer to
>> have nanoseconds as a base unit. If we think about systems in the 1GHz
>> range, having a resolution of 1000 CPU clocks seems a bit outworn to me.
> I agree with you Thomas but the existing implementations appear
> to be in microseconds.  The common name is rtems_bsp_delay().
> I wouldn't be opposed to adding an rtems_bsp_delay_nanoseconds()
> to the set.
> Jennifer and I were just looking at this.  The non-uniform nature
> of this across the BSPs is confusing.
> --joel
>> wkr,
>> Thomas.
>> Am 25.04.2011 18:02, Joel Sherrill wrote:
>>> Hi,
>>> Some BSPs have a bsp_delay method.  This is
>>> a short duration spinner.  We think it is in
>>> microsecond units but have no idea for sure
>>> and it could vary by BSP.
>>> Jennifer and I would like to formalize the
>>> definition of this.  And standardize it across
>>> BSPs.  So if it is available, it is safer to
>>> use. Questions are
>>> + OK to make a standard BSP method?
>>> + Microseconds unit?
>>> If it is not available, what should the stub do?
>>> Should we have bsp_delay_usecs() and bsp_delay_nsecs?
>>> Comments appreciated!  Please
> Joel Sherrill, Ph.D.             Director of Research&  Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>  Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
