initial eax value on x86
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Thu Aug 11 16:06:20 UTC 2011
Hello RTEMS-User,
I am a student at Dresden University of Technology and I am currently
working on a student project with the goal to get RTEMS working on L4
with the help of the L4-vCPU interface.
I have a simple HelloWorld and compiled it for i386+pc586. I load the
hello.exe elf into my program, set the IP to the entry_point, zeroed the
area between filesize and memsize and set the SP to the end of that area.
So far it works. But I get a PageFault on 100018, which is the asm
instruction:
00100018     cmp    (%eax),%dh
So after the entry point 10000c there is only one instruction touching eax:
00100010     dec    %eax
Initially %eax is 0, then its -1.
This is quite confusing and I couldn't find any hint in the start.S or
bootcard.c if eax has to be initialized with a special value.
Or did I completely miss something?
I appreciate your help.
Kind Regards,
Philipp Eppelt
