[PATCH][rtems-testing] add gcj test support for RTEMS
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Fri Aug 19 09:15:20 UTC 2011
On 08/19/2011 09:56 AM, Chris Johns wrote:
> On 19/08/11 5:38 PM, Ralf Corsepius wrote:
>> On 08/19/2011 08:56 AM, Chris Johns wrote:
>>> On 19/08/11 3:34 PM, Ralf Corsepius wrote:
>> That said, IMSHO, these scripts should not have any room in RTEMS and be
>> dumped ASAP. They are harmful and dangerous to their users's
>> installations and to the project, because they pretend doing something,
>> they don't do.
> Our views differ.
Well, some people find it acceptable to le their children play with
hand-granades - I don't.
>> Admitted, rtems-testing is not part of RTEMS, but is
>> only some people's personal playground, who believe it is doing
>> something good.
> Funny this module in cvs brings this reaction from you. I am fine with
> it. I have used these scripts for testing in the past and will again.
Pardon, but you are lying at yourselves in believing in this.
>> To me. personally rtems-testing is just a "takes
>> everything dumping ground", people are using to avoid having to cope
>> with integration.
> Or it is a take it as you find it solution for a range of problems out
> in the open for others to borrow use or ignore.
You can not be serious to expect ME to solve YOUR problems, many of
which are originating from little sought out broken and flawed designs.
Ralf
