"quit" in shell panics
Sebastian Huber
Wed Aug 31 07:36:39 UTC 2011
Hello,
the problem is that "bye" and "exit" are special cases in the shell to exit the
loop. There is also an "exit" command, which calls
rtems_fatal_error_occurred(). This command does not execute due to the special
case handling in the shell. Only its alias "quit" can be reached.
I think we should remove the shell command "exit" and all its alias. The
"shutdown N" command can be used to invoke exit(N).
On 03/03/2010 05:44 PM, Peter Dufault wrote:
> Observe:
> RTEMS SHELL (Ver.1.0-FRC):/dev/console. Mar 2 2010. 'help' to list commands.
> [/] # exit
> Shell exiting
> [/] # bye
> Shell exiting
> [/] # quit
> rtems-4.9.99.0(PowerPC/Generic (E500/float-gprs/SPE)/mpc5566evb) PANIC ERROR 0
> Obviously (I think) the shell is calling exit(0) (This is especially annoying when I did it remotely via telnet).
> There's a place where shell.c handles "bye" and "exit" specially, and I'm going to add "quit" in the same manner. I don't see where that "quit" alias is added, though. I don't have much time to go over the code right now, is there a way to get at the underlying command string so that aliases to exit are always handled cleanly without special code?
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> rtems-users mailing list
> rtems-users at rtems.org
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
