PPC Context_Control layout with __SPE__ defined
Peter Dufault
dufault at hda.com
Tue Aug 9 12:46:13 UTC 2011
On Aug 8, 2011, at 4:00 , Till Straumann wrote:
> Is there any good reason for the layout of the Context_Control struct
> being radically different (from a C- point of view)
> if __SPE__ is enabled?
> IMHO it would be preferable to adhere to the existing scheme so that
> e.g., unbundled diagnostics and tools which access register contents
> in a task context don't break.
If it is to stay as it is, what's the explanation for the naming convention:
#define PPC_CONTEXT_SET_SP( _context, _sp ) \
do { \
PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_SP ) = _sp; \
} while (0)
#define _CPU_Context_Get_SP( _context ) \
Why PPC_CONTEXT_SET_SP() versus _CPU_Context_Get_SP()? Is the second one required and used elsewhere in score?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
