rtems gcc 4.6.1 can not compile stop at check TLS
Xiangfu Liu xiangfu at sharism.cc
Wed Aug 24 14:15:59 UTC 2011
On 08/24/2011 10:10 PM, Steven Grunza wrote:
> You seem to be trying to build the compiler.  Why build the compiler
> when you can use pre-built tools?  You seem to be using a Ubuntu host.
> There is some work to be done in converting the .RPM files into .DEB
> files for Ubuntu but the Wiki page has some information on it.  See
> http://wiki.rtems.org/wiki/index.php/Debian_and_Ubuntu
the 4.6.1 not working with lm32(milkymist one) and there is one small patch
missed in 4.5.3:
  https://github.com/milkymist/scripts/blob/master/compile-lm32-rtems/milkymist-one-patches/gcc-core-0001-support-for-the-hardware-divider.patch
thanks for reply
xiangfu
