rtems gcc 4.6.1 can not compile stop at check TLS
Sebastien Bourdeauducq
sebastien at milkymist.org
Mon Aug 29 21:45:48 UTC 2011
On Mon, 2011-08-29 at 16:27 -0500, Joel Sherrill wrote:
> + Is this a reasonable and meaningful set?
> /opt/rtems-4.11/lm32-rtems4.11/lib/mmultiply-enabled/libc.a
> /opt/rtems-4.11/lm32-rtems4.11/lib/mmultiply-enabled/mbarrel-shift-enabled/libc.a
> /opt/rtems-4.11/lm32-rtems4.11/lib/libc.a
> /opt/rtems-4.11/lm32-rtems4.11/lib/mbarrel-shift-enabled/libc.a
As far as we are concerned, we only need:
mbarrel-shift-enabled/mmultiply-enabled/mdivide-enabled/msign-extend-enabled
I'm not opposed to keeping the other libraries, nor even having all 16
possible combinations (this number is unlikely to grow, as most of the
LM32 opcodes are already used) - on desktop computers, CPU and storage
are dirt cheap those days. It may seem a bit weird, though, that someone
would ever use e.g. a CPU with only the divider and nothing else, so if
you want to be picky, some combinations can definitely be left out.
S.
