Problems with printk() function
Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
victor.hoover.ctr at navy.mil
Mon Dec 19 08:25:22 UTC 2011
I'm having a couple of problems with the printk() function.
a) The optional precision value doesn't seem to be supported for
hexadecimal values (types x and X). Then again, I haven't played with
it enough yet to see if precision is supported at all...
b) If the format string does not end with a newline character, no output is
displayed.
The following are some code snippets and output displays of what I've been
running into.
Initial code (1), output display (2) and comments (3 and 4).
Modified code with more tests (5), output display (6) and comments (7).
Are these bugs or features?
1) Code from network.c
... deleted code ...
/* If we are running interrupt driven I/O no debug output is printed */
#if CD2401_IO_MODE == 0
#define printk(arglist) do { printk arglist; printk("\r"); } while (0);
#else
#endif
* print_hdr
* Print the contents of an ethernet packet header
* CANNOT BE CALLED FROM ISR
static void print_hdr(
unsigned char *add
int i;
printk (("print_hdr: begins\n"))
printk (("Header Location %p\n", add))
printk (("Dest "))
for (i = 0; i < 6; i++) {
printk ((" %2.2X", add[i]))
printk (("\nSource"))
for (i = 6; i < 12; i++) {
printk (("\nframe type %2.2X%2.2X\n", add[12], add[13]))
printk (("print_hdr: completed"))
2) Generated output
print_hdr: begins
Header Location 1173D4
.2X
.2Xce
frame type .2X.2X
3) Disclaimer
I don't know if this was called from within an ISR or from normal execution.
4) Comments
o printk does not seem to display data if the format string does not end
with a newline
o printk formatting for hex data does not seem to be working
5) Test code from rewritten network.c
#define PRINTK(...) printk(__VA_ARGS__)
#else
#define PRINTK(...)
#endif
unsigned char *add
char buf[60];
PRINTK("print_hdr: begins\n");
PRINTK("Header Location %p\n", add);
PRINTK("Dest %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
add[0], add[1], add[2], add[3], add[4], add[5]);
printk("Dest %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
printk("Dest %2X:%2X:%2X:%2X:%2X:%2X\n",
printk("Dest %X:%X:%X:%X:%X:%X\n",
sprintf(buf, "Dest %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
PRINTK("%s", buf);
PRINTK("Source %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
add[6], add[7], add[8], add[9], add[10], add[11]);
printk("Source %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
printk("Source %2X:%2X:%2X:%2X:%2X:%2X\n",
printk("Source %X:%X:%X:%X:%X:%X\n",
sprintf(buf, "Source %2.2x:%2.2x:%2.2x:%2.2x:%2.2x:%2.2x\n",
PRINTK("%s", buf);
PRINTK("frame type %2.2x%2.2x\n", (unsigned int)add[12], (unsigned int)add[13]);
PRINTK("print_hdr: completed\n");
6) Generated output
print_hdr: begins
Header Location 116ED4
Dest .2x:.2x:.2x:.2x:.2x:.2x
Dest FF:FF:FF:FF:FF:FF
Dest ff:ff:ff:ff:ff:ff
Source .2x:.2x:.2x:.2x:.2x:.2x
Source 8: 0:3E:27: A:AF
Source 8:0:3E:27:A:AF
Source 08:00:3e:27:0a:af
frame type .2x.2x
7) Comments
o Problem does not seem to be interrupt related
o printk does not display correct data for hex data when a precision is
specified
o sprintf and printf work correctly
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20111219/a59c8142/attachment.bin>
