MPC5634M starting point
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Fri Dec 30 21:38:00 UTC 2011
Andrei,
I am off site now, but my colleague Sebastian Huber is currently working
on the MPC55xx BSP, also adapting it to the MPC5674F, see
http://wiki.rtems.org/wiki/index.php/MPC5674FEVB
But you should upgrade to the latest git version of RTEMS to work with it.
wkr,
Thomas.
The mpc55xx BSP is a framework, including adaptions for various boards
and chips, therefore it won't compile for a target "mpc55xx".
Am 30.12.2011 21:38, schrieb Andrei Chichak:
> Hey all,
> A while back I got a hand from Chris to get started with the MC68332,
> then Eric Norum helped me get a BSP going for the Axiom CML5282, again
> 68K based.
> Now I am getting going on one of Freescale's MPC5634M StarterTRAK dev
> board. It uses a PPC with hardware floating point.
> I am currently using RTEMS 4.9.4 on a windows VM using MINGW/MSYS. I
> didn't move up to 4.10 yet, since it wasn't stable when I was working on
> that project.
> To get the basics going I used:
> cd powerpc
> ../rtems-4.9.4/configure --target=powerpc-rtems4.9 \
> --disable-itron \
> --enable-posix \
> --enable-rtemsbsp='mpc55xx' \
> --enable-networking \
> --disable-tests \
> --prefix /c/opt/src/rtems/powerpc
> make all install
> since I figured that a 55xx would be within a million miles. This is
> basically the same command that I use to set up for the m68k based BSPs
> (with appropriate changes of parameters of course).
> For some odd reason it looks like the 55xx BSP wasn't installed
> properly, since it didn't compile the libraries for a couple of hours.
> It also looks like the distribution has the mpc55xx BSP and mpc55xxevb,
> but it looks like portions are missing.
> Is there someone using either the 5632M or a 55xx that can suggest a
> better config command to get started?
> Sorry that I'm not as concise and complete as you might hope, my first
> language isn't German :-)
> Andrei
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
