EL6 RPMs for Fedora 14 Issue
Peter Dufault
dufault at hda.com
Thu Dec 22 12:09:37 UTC 2011
On Dec 22, 2011, at 6:49 , Ralf Corsepius wrote:
> CentOS is a server distro, which is aiming at "long term API stability".
> In general, it's a good choice to run a web-server or a data base server
> on it, but is a bad choice for development purposes.
I would have agreed until I found the EPEL (Extra Packages for Enterprise Linux) packages. Centos/Epel may not be good for working on the head, but it is good for working on products, and with the EPEL packages I've only had to build a few things myself. That's also why it's on a virtual machine.
I'm probably going to be stuck with two development environments. The above, for working on products, and Fedora for extending RTEMS itself.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
