MPCI Driver
Sebastian Huber
Thu Feb 3 10:35:35 UTC 2011
Hello,
a MPCI (Multiprocessor Communications Interface) driver must provide these
functions:
* This type defines the Multiprocessor Communications
* Interface (MPCI) Table. This table defines the user-provided
* MPCI which is a required part of a multiprocessor system.
* For non-blocking local operations that become remote operations,
* we need a timeout. This is a per-driver timeout: default_timeout
typedef struct {
/** This fields contains the timeout for MPCI operations in ticks. */
uint32_t default_timeout;
/** This field contains the maximum size of a packet supported by this
* MPCI layer. This size places a limit on the size of a message
* which can be transmitted over this interface.
size_t maximum_packet_size;
/** This field points to the MPCI initialization entry point. */
MPCI_initialization_entry initialization;
/** This field points to the MPCI get packet entry point. */
MPCI_get_packet_entry get_packet;
/** This field points to the MPCI return packet entry point. */
MPCI_return_packet_entry return_packet;
/** This field points to the MPCI send packet entry point. */
MPCI_send_entry send_packet;
/** This field points to the MPCI receive packet entry point. */
MPCI_receive_entry receive_packet;
} MPCI_Control;
I have a question regarding the send packet entry. Does the send packet also
include a return packet semantic? This would imply that the usage of a packet
after a call to the send packet entry is invalid.
Locking at the code is a bit confusing. For example in
_Message_queue_MP_Send_request_packet() we get a packet, prepare the packet and
hand it over to _MPCI_Send_request_packet(). Since no references to the packet
are stored, I assume that _MPCI_Send_request_packet() will release the packet.
Inside _MPCI_Send_request_packet() we make a call to send packet, but no call
to return packet. So I assume that a send packet implies a packet return. On
the other hand we use some packet values after the send packet (lines 275 to
278 in mpci.c). Is this correct?
Have a nice day!
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
