Why does RTEMS have its own toolchain?
Tue Feb 8 20:01:15 UTC 2011
On 02/08/2011 01:41 PM, Rohan Kangralkar wrote:
> Hi,
> Why does RTEMS provide us with its own version of compiler which is
> based on gnu gcc.
The compiler settings are tuned to match RTEMS.   The C library and
RTEMS cooperatively
provide POSIX functionality.  This is built with the compiler and is
matched to the RTEMS
version.
> Can we use the bfin toolchain from uclinux
> (http://blackfin.uclinux.org/gf/) for blackfin or gcc-arm-coff for arm
> compilation?.
No.  As a minimum they will not define the proper cpp defines, include
the right
C library, and possibly not include a proper set of multilibs.  I can
also almost
guarantee that the RTEMS tools will track the FSF tool projects better and
include appropriate bug fixes.  We usually are the first project to release
RPMs based upon new gcc versions.
FWIW you shouldn't be using COFF on any target where ELF is available.
> ___________________________
> Thanks and regards
> Rohan Kangralkar
> Northeastern University
> ECE department
> kangralkar.r at neu.edu <mailto:kangralkar.r at neu.edu>
Joel Sherrill, Ph.D.             Director of Research&  Development
