Possible problem with CONFIGURE_MAXIMUM_SEMAPHORES succeeding
Eric Norum
wenorum at lbl.gov
Thu Feb 10 21:22:44 UTC 2011
The actual number of semaphores configured into the system depends upon more than just the value you provide for CONFIGURE_MAXIMUM_SEMAPHORES.
Here's the salient code from confdefs.h:
#define CONFIGURE_SEMAPHORES \
(CONFIGURE_MAXIMUM_SEMAPHORES + CONFIGURE_LIBIO_SEMAPHORES + \
CONFIGURE_TERMIOS_SEMAPHORES + CONFIGURE_LIBBLOCK_SEMAPHORES)
Thus your test is merely soaking up some of the semaphores configured for other possible use.
On Feb 10, 2011, at 1:15 PM, Andrei Chichak wrote:
> Hi all,
> I was adding another semaphore to my code and decided to test the semaphore create failure case first. I added the create without incrementing the maximum number of semaphores that was configured. The create succeeded rather than failed.
> I created 4 semaphores with the maximum set to 3. All returned rtems_status_code == 0. I set the maximum to 2, same. I set the maximum to 1, same. I set the maximum to 0, same result.
> This is running on an Axiom CML5282 using RTEMS 4.9.4 and a BSP that is heavily based on the AV5282 and UC5282 BSPs.
> Any ideas?
> I started stripping out code until my program generates this:
> create sem1 semaphore returned with 0
> create sem2 semaphore returned with 0
> create sem3 semaphore returned with 0
> create sem4 semaphore returned with 0
> From this (only comments have been removed):
> #include <rtems.h>
> rtems_task Init(rtems_task_argument ignored);
> #include <bsp.h>
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 0
> #define CONFIGURE_MAXIMUM_SEMAPHORES 0
> #define CONFIGURE_MAXIMUM_TIMERS 0
> #define CONFIGURE_MAXIMUM_PARTITIONS 0
> #define CONFIGURE_MAXIMUM_DRIVERS 20
> #define STACK_CHECKER_ON
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
> static rtems_id sem1;
> static rtems_id sem2;
> static rtems_id sem3;
> static rtems_id sem4;
> rtems_task Init(rtems_task_argument ignored) {
> rtems_status_code status;
> status = rtems_semaphore_create( rtems_build_name('S','E','M','1'),
> 1,
> RTEMS_PRIORITY | RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING | RTEMS_LOCAL,
> 0,
> &sem1);
> printk("create sem1 semaphore returned with %d\n", status);
> status = rtems_semaphore_create( rtems_build_name('S','E','M','2'),
> 1,
> 0,
> &sem2);
> printk("create sem2 semaphore returned with %d\n", status);
> status = rtems_semaphore_create( rtems_build_name('S','E','M','3'),
> 1,
> 0,
> &sem3);
> printk("create sem3 semaphore returned with %d\n", status);
> status = rtems_semaphore_create( rtems_build_name('S','E','M','4'),
> 1,
> 0,
> &sem4);
> printk("create sem4 semaphore returned with %d\n", status);
> status = rtems_task_delete( RTEMS_SELF);
> exit(0);
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
URL: <http://lists.rtems.org/pipermail/users/attachments/20110210/5645c96a/attachment.html>
