RES: RTEMS Application building
Thu Feb 17 13:35:57 UTC 2011
On 02/17/2011 07:17 AM, Wendell Pereira da Silva wrote:
> Hi Padmakumar,
> The hello.exe generated after make is actually a image which contains
> the RTEMS kernel and the application statically linked. So it won’t
> work this way.
> Instead, you will need to boot it up. I suggest running it by using
> QEMU. Follow this <http://www.rtems.com/wiki/index.php/QEMU> is a good
> start.
And to follow up, the "rtems-testing" CVS module has scripts and helper
files for simulators.  See the directory qemu-support for a floppy image
which
automatically boots a file from a virtual hard drive.  This plus the
script "pc386" in that module will help you.  Then...
pc386 -i XXX.exe
The -i is for interactive rather than the default which is to log output
to a file.
--joel
> Wendell.
> *De:*rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] *Em nome de *Padmakumar . P
> *Enviada em:* quinta-feira, 17 de fevereiro de 2011 07:08
> *Para:* rtems-users at rtems.org
> *Assunto:* RTEMS Application building
> Hi ,
> I am quite new to RTEMS and trying to understand its working.
> I am using Virtual Box with Ubuntu 10.10 as host environment.
> Successfully installed 4.10 toolkit and  rtems-4.10 for target = i386
> and BSP = pc686.
> Successfully build the Hello World application. it created the
> hello.exe after make. But when i tryied to run the "exe", I am getting
> the message KILLED.
> Did I miss anything or any idea about this problem?
> Thanks in Advance.
> PKP
Joel Sherrill, Ph.D.             Director of Research&  Development
