Build Failure with 4.10 lm32
Graham Henderson
graham615 at yahoo.com
Fri Feb 18 02:38:17 UTC 2011
Chris:
I figured it out and posted to the list.....the post got bounced back due to the size.
"When asked to install the build tools, I guess it means ALL the build tools. I installed the automake and autoconf from http://www.rtems.org/ftp/pub/rtems/cygwin/4.10/, re-executed bootstrap, configure and make. Given my new-found confidence, I may attempt this under MinGW."
Anyway, thanks for the offer to help....as you can see it was a tools issues that I just needed to work through. I received the Lattice dev board today and will begin the process of creating a configuration and get a simple application running.
Best,
Graham....
To: Graham Henderson <graham615 at yahoo.com>
Cc: "rtems-users at rtems.org" <rtems-users at rtems.org>
Sent: Thursday, February 17, 2011 5:51 PM
Subject: Re: Build Failure with 4.10 lm32
On 17/02/11 12:59 PM, Graham Henderson wrote:
> I have included the output of configure and make as well as my path and
> the contents of the tool directory. I am new at this ( two days) and at
> a loss. Any advice would be appreciated.
I suspect something is happening before getting to here that is causing the problem.
I do not know your time zone but I am currently on IRC so if you can drop by maybe we can figure this out.
URL: <http://lists.rtems.org/pipermail/users/attachments/20110217/4c91fb57/attachment.html>
