Build Failure with 4.10 lm32
Fri Feb 18 05:09:36 UTC 2011
On 18/02/11 4:03 PM, Ralf Corsepius wrote:
> The issue you recall is mingw shipping an obsolete version of perl,
> which would be suitable for submission to a computer museum (ca. 10
> years old).
I had forgotten the issue. Those museums scare me. I can remember when
the stuff in them was new. :)
> This once had caused issues with cross-building automake, causing the
> rtems.org automake packages to be unusable on MinGW.
> However, this is supposed to be fixed now and therefore should not be an
> issue anymore.
Excellent.
> Finally, a general reoccuring issue with both mingw and cygwin is them
> shipping an autoconf-wrapper script, which is causing a lot of issues
> all over the place - My recommendation: Deinstall it, it's dysfunctional.
I did not know this. I will try and take a look.
