Is there any change on interrupt catch between RTEMS 4.9.4 and 4.10.0?
Filipe Cividanes
cividanesfilipe at yahoo.com.br
Mon Feb 21 19:32:52 UTC 2011
Hi Joel
Thanks for the quick answer. In fact I´m not using the console driver, just rtems_interrupt_catch to get characters and printf to send responses - it´s pretty simple.
Any other idea ?
Thanks in advance and best regards,
Filipe Cividanes
PS: the 'Interrupt Extension API' link on http://www.rtems.org/wiki/index.php/4.10_Release_Notes is broken.
--- Em seg, 21/2/11, Joel Sherrill <joel.sherrill at oarcorp.com> escreveu:
De: Joel Sherrill <joel.sherrill at oarcorp.com>
Assunto: Re: Is there any change on interrupt catch between RTEMS 4.9.4 and 4.10.0?
Para: "Filipe Cividanes" <cividanesfilipe at yahoo.com.br>
Cc: "rtems-users at rtems.org" <rtems-users at rtems.org>
Data: Segunda-feira, 21 de Fevereiro de 2011, 19:19
On 02/21/2011 01:01 PM, Filipe Cividanes wrote:
> Hi all,
> I've recompiled and run two simple applications, thet use ISRs to manage a console/terminal interface.
> The BSP is SPARC/SIS. Both applications run successfully on RTEMS 4.9.4, but not on 4.10.0. They simply stop running just after 'rtems_interrupt_catch' is called for the UART A. In fact, it seems that they stop on the first 'printf' after the interrupt catch.
> Does anyone have noticed this behavior? Has something changed on interrupt catch between 4.9.4 and 4.10.0? Could be something new on gcc's printf for the SPARC architecture?
There are no interrupt changes.
The console driver was rewritten between 4.9 and 4.10. It is possible
something slipped through the testing. You probably should compare the
two console drivers with a view toward the mode you are using.
2010-04-27 Tiemen Schut <T.Schut at sron.nl>
PR 1506/bsps
* console/console.c: Removed.
* console/erc32_console.c: New file. Use shared console driver.
Make sure interrupt support works. PPPD confirmed on sis.
* Makefile.am: Reflect changes above.
> Filipe Cividanes.
-- Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20110221/b7256a73/attachment.html>
