RTEMS - rtems_clock_get_uptime() fails during timer tick
Rolf Schroedter rolf.schroedter at dlr.de
Thu Feb 24 07:51:39 UTC 2011
I tried to protect the call to rtems_clock_get_uptime() from interrupts
(this was easier than to recompile RTEMS):
#define _get_uptime( _ptr_uptime )        \
     rtems_interrupt_level   _level;        \
     rtems_interrupt_disable(_level);        \
     rtems_clock_get_uptime( _ptr_uptime );    \
     rtems_interrupt_enable(_level);        \
But surprisingly (at least for me) this didn't solve the problem.
Okay, I'll try to grab into the RTEMS sources.
Thanks & regards,
Rolf.
On 24.02.2011 01:23, Gedare Bloom wrote:
> Hi,
> I suppose if your code is interrupting the rtems_clock_tick, this
> behavior might happen. Can you try to add an ISR_Disable / ISR_Enable
> protection around the call to "_Timestamp_Add_to(&_TOD_Uptime,&tick
> );" in cpukit/score/src/coretodtickle.c and see if the problem
> disappears?
> -Gedare
