RTEMS - rtems_clock_get_uptime() fails during timer tick
Thu Feb 24 08:47:02 UTC 2011
Hello Rolf,
this looks like a general problem with the
_Watchdog_Nanoseconds_since_tick_handler() mechanic.  Lets suppose we have a
hardware timer with an automatic reload capability.  It counts from 0 to N,
then goes back to 0, and so on.  It triggers an interrupt during the N to 0
transition.  The _Watchdog_Nanoseconds_since_tick_handler() returns the current
hardware timer ticks mapped to nanoseconds.  Lets have a look at this function.
void _TOD_Get_uptime(
  Timestamp_Control *uptime
  ISR_Level         level;
  Timestamp_Control offset;
  Timestamp_Control up;
  long              nanoseconds;
  /* assume time checked for NULL by caller */
  /* _TOD_Uptime is in native timestamp format */
  _ISR_Disable( level );
    up = _TOD_Uptime;
    nanoseconds = (*_Watchdog_Nanoseconds_since_tick_handler)();
  _ISR_Enable( level );
  _Timestamp_Set( &offset, 0, nanoseconds );
  _Timestamp_Add_to( &up, &offset );
  *uptime = up;
Now consider the following sequence.  We are right before the hardware timer N
to 0 transition.  We disable the interrupts in the above function.  The
hardware timer goes to 0.  Since interrupts are disabled, the _TOD_Uptime is
not up to date.  We call _Watchdog_Nanoseconds_since_tick_handler() and get the
time since the last hardware (!) timer tick.  Now we use the out of date uptime
with the new nanoseconds.
A solution may be to not disable interrupts in _TOD_Get_uptime() (and all
calling contexts) and use something like this:
do {
	up0
	nanoseconds
	up1
} while (up0 != up1)
Have a nice day!
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
