[Milkymist-devel] milkymist network driver bug
Yann Sionneau yann at minet.net
Thu Feb 24 14:55:10 UTC 2011
Le 24/02/11 14:40, Till Straumann a écrit :
> On 02/24/2011 03:12 PM, Sebastien Bourdeauducq wrote:
>> On Thu, 2011-02-24 at 11:13 +0000, Yann Sionneau wrote:
>>> Feel free to merge these commits with the CVS, but it will not be a
>>> straight forward merge since my github repository has a lot of commit
>>> that your CVS doesn't have. We are out of sync.
>> Joel told me that the 4.11 release is not before a while. To reduce the
>> administrative overhead, and unless someone sees this as an
>> inconvenience, let's continue working on this BSP in the Git repository
>> for now and I'll submit one big patch before the 4.11 release.
>> S.
> Hmm - but I'd rather get only the BSP from your git repo
> and work with the main-line RTEMS otherwise.
> How can I do that?
> Thanks
Well you can checkout my git repo, it's a clone of RTEMS CVS of when I
started the GSoC back in the middle of 2010.
Just check it out and you can play with RTEMS and the up-to-date
Milkymist BSP as if you were playing with RTEMS CVS :)
The qemu to use is a special one (with milkymist support) btw, it's the
one from this git repo :
http://git.serverraum.org/?p=mw/qemu-lm32.git;a=summary
Link for how to compile lm32-qemu :
http://milkymist.org/wiki/index.php?title=Using_QEMU
Link for how to compile the BSP (but you sure know how to do that better
than me :)) :
http://milkymist.org/wiki/index.php?title=RTEMS_build_instructions
Link on how to run some tests :
http://milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
And eventually if you want to try flickernoise (a GUI application) :
http://milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
Have fun :)
Yann Sionneau
