ARM Cortex-M3
Ralf Corsepius ralf.corsepius at rtems.org
Mon Feb 7 22:57:30 UTC 2011
On 02/07/2011 11:29 PM, Peter Dufault wrote:
> On Feb 7, 2011, at 12:46 , Ralf Corsepius wrote:
>> ... except that these versions are hopelessly outdated (You will really
>> want to use the rtems-4.11 versions), there shouldn't be much wrong with
>> this.
> Do you mean that he should also switch to 4.11 RTEMS or just tools?
Depends ...
> I'm asking because I'm about to rebuild my 4.10 mpc5554 BSP, and to get started I fetched all the tools from the 4.10 location on the FTP site.
> For my mpc5554 application I make a multilib with "-mfloat-gprs=single -mspe".
> Is that the right thing to do?
... for implementing a new target or multilib and active development,
I'd recommend using "rtems4.11"+accompanied toolchains, because this is
were active development goes into.
... for "production works", I'd recommend using "rtems4.10"+accompanied
toolchains, because they, except that still no tarball has been
released, are "stable".
rtems4.9, though it's still officially labeled "stable", as far as I am
concerned, and though some people will want to kill me for saying so,
actually is de-facto "dead".
I.e. to the OP, I'd recommend rtems4.11 (comprising gcc-4.5.2,
binutils-2.21). To you, rtems4.10 likely is the preferrable choice.
Ralf
