TCP issue with large packet under RTEMS
Yann Sionneau
yann at minet.net
Wed Feb 9 17:26:21 UTC 2011
Hi Joao,
The fact that recv() can return before receiving everything you expect,
and is non-blocking, is the standard way of functionning for recv().
This is the POSIX way, if you do man recv on a Linux system for example
you will see that this behaviour is documented.
This is the correct behaviour of recv(), you have to run it inside a
loop if you want to be sure to receive all the data you need.
On Linux there is a flag MSG_WAITALL that you can pass to recv() to make
it wait untill it receives the amount of data you tell him to get. I
don't know if it is implemented in RTEMS TCP/IP protocol stack.
Regards,
Yann Sionneau
Le 09/02/11 17:10, João Rasta a écrit :
> Hi Joel, Eric,
> I followed Eric's suggestion and it worked. I thought that read() should
> be automatically blocking untill all numelements passed to the read()
> function were read. I wonder why read() exits without this condition to
> fulfill..
> Joel, how can i increase the TCP/IP stack size in order to get more
> performance out of the read routine? I mean, using only one system call
> to get the whole data would be perfect. Previously the application did
> not lock, it simply returned the read with less bytes than the buffer
> size and continued executing.
> Thanks a lot.
> Best,
> JM
> On Wed, Feb 9, 2011 at 4:55 PM, Eric Norum <wenorum at lbl.gov
> <mailto:wenorum at lbl.gov>> wrote:
> TCP (SOCK_STREAM) receivers always need to expect to have to
> complete their reads in multiple operations -- you need to put your
> read call in a loop:
> char *buf;
> ssize_t nleft, nread;
> buf = .....
> nleft = .....
> while (nleft) {
> nread = read(sd, buf, nleft);
> if (nread < 0)
> error......
> if (nread == 0)
> end-of-file......
> buf += nread;
> nleft -= nread;
> On Feb 9, 2011, at 8:36 AM, João Rasta wrote:
> > Hi,
> > I'm using RTEMS 4.10 and GRETH MAC in order to exchange data with
> a client PC via TCP. I have a LEON-3 based processor architecture. I
> can successfully attach the GRETH ethernet driver using the RTEMS
> driver manager and exchange small ammounts of data. However, when i
> need to transfer an image array (436160Bytes) from the PC to the
> RTEMS system, the read() call only returns 17508Bytes read instead
> of 436160Bytes .
> > The send() directive in the PC side returns the correct number of
> bytes sent so the problem must be on the RTEMS side. The read buffer
> has the correct size.
> > 1) Is there any programmable limitation related to the number of
> bytes to receive? Since i'm using a TCP socket, there is no apparent
> reason for byte loss i guess..
> > 2) In what circumstances should read() from a TCP socket return
> less bytes than the ones sent?
> > Best,
> > JM
> Eric Norum
> wenorum at lbl.gov <mailto:wenorum at lbl.gov>
