milkymist network driver bug
Gedare Bloom
gedare at gwmail.gwu.edu
Thu Feb 24 00:28:17 UTC 2011
PR 1739 addresses this sizing issue. I think the bulk of the work on
this BSP came in last years GSOC, so it could probably use some
additional review/oversight before use.
On Wed, Feb 23, 2011 at 7:18 PM, Till Straumann
<strauman at slac.stanford.edu> wrote:
> Today I started playing with the milkymist BSP in HEAD.
> After some hacking I got some life out of lm32-qemu and this
> BSP but I'm not sure it has reached production quality quite yet.
> When sending a packet, minimac_sendpacket() copies the
> entire mbuf chain holding the packet into a driver-buffer
> (struct mm_packet) which is much smaller than the interface
> MTU and which is allocated *on*the*stack* and then handed
> (by reference) to the chip (for DMA, I guess).
> Any packet that is larger than 128 bytes overruns the stack
> and since it is very likely that the packet buffer is popped
> before the hardware is done reading it from memory it may
> very well be corrupted.
> Other peculiarities include not declaring memory-mapped
> registers as 'volatile' (in the network- and other drivers).
> -- T.
> PS: Here's a snippet of that code
> static void minimac_sendpacket(struct ifnet *ifp, struct mbuf *m)
> struct mbuf *nm = m;
> struct minimac_softc *sc = &minimac_softc;
> unsigned int len = 0;
> struct mm_packet p;
> unsigned int crc;
> uint8_t i;
> for (i = 0 ; i < 7 ; i++) // Preamble
> p.preamble[i] = 0x55;
> p.preamble[7] = 0xd5;
> do
> unsigned int mlen;
> mlen = nm->m_len;
> if (nm->m_len > 0) {
> m_copydata(nm, 0, mlen, p.raw_data + len);
> len += nm->m_len;
> } while ( (nm = nm->m_next) != 0 );
> for ( ; len < 60 ; len++)
> p.raw_data[len] = 0x00; // Padding
> crc = mm_ether_crc32((uint8_t *)p.raw_data, len); // CRC32
> p.raw_data[len] = crc & 0xff;
> p.raw_data[len+1] = (crc & 0xff00) >> 8;
> p.raw_data[len+2] = (crc & 0xff0000) >> 16;
> p.raw_data[len+3] = crc >> 24;
> len += 4; // We add 4 bytes of CRC32
> if (len + 8 < 64) {
> printk("[minimac] Packet is too small !\n");
> sc->txErrors++; // update stats
> return;
> minimac_write(MM_MINIMAC_TXADR, (unsigned int)&p);
> minimac_write(MM_MINIMAC_TXREMAINING, (unsigned int)(len + 8));
> where struct mm_packet is
> struct mm_packet {
> unsigned char preamble[8];
> char raw_data[MLEN]; /* MLEN == 128 bytes! */
> } __attribute__((aligned(4), packed));
> rtems-users mailing list
> rtems-users at rtems.org
