[Milkymist-devel] milkymist network driver bug
Daron Chabot
daron.chabot at gmail.com
Thu Feb 24 16:34:59 UTC 2011
Hi Till,
I'm not sure if Yann is doing the same, but I've been tracking the RTEMS cvs
repos with git for some time and update it semi-regularly (doing an update
now). I maintain one git repo that is a "mirror" of the cvs repo, and
another git repo (clone of the mirror) for local development where I
"rebase" my work on top of the cvs HEAD.
You could do something similar, pulling Yann's branch(es) into your
scratchpad repo...
Just a thought.
-- dc
On Thu, Feb 24, 2011 at 10:17 AM, Till Straumann <strauman at slac.stanford.edu
> wrote:
> On 02/24/2011 03:55 PM, Yann Sionneau wrote:
>> Le 24/02/11 14:40, Till Straumann a écrit :
>>> On 02/24/2011 03:12 PM, Sebastien Bourdeauducq wrote:
>>>> On Thu, 2011-02-24 at 11:13 +0000, Yann Sionneau wrote:
>>>>> Feel free to merge these commits with the CVS, but it will not be a
>>>>> straight forward merge since my github repository has a lot of commit
>>>>> that your CVS doesn't have. We are out of sync.
>>>> Joel told me that the 4.11 release is not before a while. To reduce the
>>>> administrative overhead, and unless someone sees this as an
>>>> inconvenience, let's continue working on this BSP in the Git repository
>>>> for now and I'll submit one big patch before the 4.11 release.
>>>> S.
>>> Hmm - but I'd rather get only the BSP from your git repo
>>> and work with the main-line RTEMS otherwise.
>>> How can I do that?
>>> Thanks
>> Well you can checkout my git repo, it's a clone of RTEMS CVS of when I
>> started the GSoC back in the middle of 2010.
> Well - that's not exactly what I want. I want to stay in-sync with
> the current RTEMS development and use your latest BSP.
> T.
>> Just check it out and you can play with RTEMS and the up-to-date
>> Milkymist BSP as if you were playing with RTEMS CVS :)
>> The qemu to use is a special one (with milkymist support) btw, it's the
>> one from this git repo :
>> http://git.serverraum.org/?p=mw/qemu-lm32.git;a=summary
>> Link for how to compile lm32-qemu :
>> http://milkymist.org/wiki/index.php?title=Using_QEMU
>> Link for how to compile the BSP (but you sure know how to do that better
>> than me :)) :
>> http://milkymist.org/wiki/index.php?title=RTEMS_build_instructions
>> Link on how to run some tests :
>> http://milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
>> And eventually if you want to try flickernoise (a GUI application) :
>> http://milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
>> Have fun :)
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20110224/7d090c0f/attachment-0001.html>
