[Milkymist-devel] milkymist network driver bug
Daron Chabot daron.chabot at gmail.com
Thu Feb 24 21:35:46 UTC 2011
I would like to get Joel's blessing before I go about making this publicly
accessible. Then I have to figure out where to put it !
I'll ping the list when/if both are resolved.
-- dc
On Thu, Feb 24, 2011 at 3:47 PM, Yann Sionneau <yann at minet.net> wrote:
> Hi Daron,
> Thanks for the commands, I would greatly appreciate a public git repository
> with all that already set-up if it is so long and bandwidth consuming to do.
> So that I could git clone it.
> Thanks !
> Le 24/02/11 20:03, Daron Chabot a écrit :
>> On Thu, Feb 24, 2011 at 1:07 PM, Yann Sionneau <yann at minet.net
>> <mailto:yann at minet.net>> wrote:
>>    Hi Daron,
>>    How did you do your git mirror of the CVS ? Is there any tool to do
>>    that ?
>> I simply used what git provides. See, "git help cvsimport".
>> The first step is doing a cvs checkout (HEAD will work):
>> 1)    cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS co rtems
>> 2)    mv rtems rtems.cvs
>> Then the commands I use to create my pristine, git-mirror of the CVS
>> repo is:
>>  3)   cd rtems.cvs
>>  4)   git cvsimport -i -v -C ../rtems.mirror.git
>> !!!!!!!!!!!!!!! Beware: this will take *many* hours over the network
>> i.e. do this at night (Alabama time) if you want to avoid annoying repo
>> users/administrators.
>> I seem to recall this initially taking on the order of nine hours. If
>> done locally, this operation is orders of magnitude faster (wink, wink,
>> nudge, nudge Joel).
>> If people are interested, I may be able to put my "rtems.mirror.git" in
>> a publicly accessible location to spare them the 10 hours of suspense.
>> To update the git-mirror when the CVS repo changes, just repeat 3) and
>> 4). This will take around 15 min over the network.
>> As recommended by the "git-cvsimport" man page, *do not* use the
>> git-mirror for working in. Do this:
>> 5)    git clone rtems.mirror.git rtems.git       # assuming you want
>> these in same directory
>> Then, use the "rtems.git" repo to play around in...
>> FYI -- my "rtems.mirror.git" branches look like this:
>> (~/RTEMS/rtems.mirror.git)
>> djc at TooLBox--> git branch -a
>>   B_beatnik_import_from_SLAC
>>   B_rtems_mvme3100_bsp_slac
>>   MOVED-ASM_H-TO-RTEMS-SUBDIR-4-6-branch
>>   MOVED-FROM-C-SRC-EXEC-TO-CPUKIT-rtems-eng-200108xx
>>   MOVED-FROM-C-SRC-TO-CPUKIT-rtems-4-5-branch
>>   MOVED-FROM-LIBBSP-TO-LIBCHIP-rtems-4-6-branch
>>   MOVED-FROM-SCORE-TO-RTEMS-rtems-4-6-branch
>>   MOVED-FTPD-TO-CPUKIT-4-5-branch
>>   MOVED-RTEMS_WEBSERVER-TO-CPUKIT-HTTPD-4-5-branch
>>   MOVED-TO-LIBCPU-4-6-branch
>>   MOVED-from-C-SRC-TO-CPUKIT-rtems-4-5-branch
>>   MOVED-from-C-SRC-TO-CPUKIT-rtems-4-6-branch
>>   OAR
>>   SLAC
>> * master
>>   origin
>>   rtems-4-0-0-branch
>>   rtems-4-10-branch
>>   rtems-4-5-branch
>>   rtems-4-6-branch
>>   rtems-4-7-branch
>>   rtems-4-8-branch
>>   rtems-4-8-testing
>>   rtems-4-9-branch
>>   rtems-am-branch
>>   rtems-eng-200108xx
>>   rtemsdoc-4-5-branch
>>   shttpd
>>   zlib
>> "master" ---> HEAD, all the rtems-4-X-branches appear as in the CVS
>> repo, and I really don't know (or care!) about the rest.
>> HTH.
>> -- dc
>>    Did you just cvs checkout and then git init . && git add * ?
>>    You had to keep the CVS related files into your git, in order to be
>>    able to to cvs up, right ?
>>    Can you explain to me how to do like you ?
>>    Thanks :)
>>    Regards,
>>    Yann
>>    Le 24/02/11 16:34, Daron Chabot a écrit :
>>        Hi Till,
>>        I'm not sure if Yann is doing the same, but I've been tracking
>>        the RTEMS
>>        cvs repos with git for some time and update it semi-regularly
>>        (doing an
>>        update now). I maintain one git repo that is a "mirror" of the
>>        cvs repo,
>>        and another git repo (clone of the mirror) for local development
>>        where I
>>        "rebase" my work on top of the cvs HEAD.
>>        You could do something similar, pulling Yann's branch(es) into your
>>        scratchpad repo...
>>        Just a thought.
>>        -- dc
>>        On Thu, Feb 24, 2011 at 10:17 AM, Till Straumann
>>        <strauman at slac.stanford.edu <mailto:strauman at slac.stanford.edu>
>>        <mailto:strauman at slac.stanford.edu>>> wrote:
>>            On 02/24/2011 03:55 PM, Yann Sionneau wrote:
>>                Le 24/02/11 14:40, Till Straumann a écrit :
>>                    On 02/24/2011 03:12 PM, Sebastien Bourdeauducq wrote:
>>                        On Thu, 2011-02-24 at 11:13 +0000, Yann Sionneau
>>        wrote:
>>                            Feel free to merge these commits with the
>>        CVS, but
>>                            it will not be a
>>                            straight forward merge since my github
>>        repository
>>                            has a lot of commit
>>                            that your CVS doesn't have. We are out of sync.
>>                        Joel told me that the 4.11 release is not before a
>>                        while. To reduce the
>>                        administrative overhead, and unless someone sees
>>        this as an
>>                        inconvenience, let's continue working on this
>>        BSP in the
>>                        Git repository
>>                        for now and I'll submit one big patch before the
>>        4.11
>>                        release.
>>                        S.
>>                    Hmm - but I'd rather get only the BSP from your git
>> repo
>>                    and work with the main-line RTEMS otherwise.
>>                    How can I do that?
>>                    Thanks
>>                Well you can checkout my git repo, it's a clone of RTEMS
>>        CVS of
>>                when I
>>                started the GSoC back in the middle of 2010.
>>            Well - that's not exactly what I want. I want to stay
>>        in-sync with
>>            the current RTEMS development and use your latest BSP.
>>            T.
>>                Just check it out and you can play with RTEMS and the
>>        up-to-date
>>                Milkymist BSP as if you were playing with RTEMS CVS :)
>>                The qemu to use is a special one (with milkymist
>>        support) btw,
>>                it's the
>>                one from this git repo :
>>        http://git.serverraum.org/?p=mw/qemu-lm32.git;a=summary
>>                Link for how to compile lm32-qemu :
>>        http://milkymist.org/wiki/index.php?title=Using_QEMU
>>                Link for how to compile the BSP (but you sure know how to
>> do
>>                that better
>>                than me :)) :
>>        http://milkymist.org/wiki/index.php?title=RTEMS_build_instructions
>>                Link on how to run some tests :
>> http://milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
>>                And eventually if you want to try flickernoise (a GUI
>>        application) :
>> http://milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
>>                Have fun :)
>>            _______________________________________________
>>            rtems-users mailing list
>>        rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>        <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>>        http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20110224/acc0bd2c/attachment-0001.html>
