[Milkymist-devel] milkymist network driver bug
Daron Chabot
daron.chabot at gmail.com
Thu Feb 24 22:37:48 UTC 2011
yep. +1.
On Thu, Feb 24, 2011 at 5:18 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 02/24/2011 03:35 PM, Daron Chabot wrote:
>> I would like to get Joel's blessing before I go about making this publicly
>> accessible. Then I have to figure out where to put it !
>> I'll ping the list when/if both are resolved.
>> There is an RTEMS Git repository at http://www.rtems.org/ftp/private/gitwhich
> is updated once an hour. Is it time to move it to a move public location?
> --joel
>> -- dc
>> On Thu, Feb 24, 2011 at 3:47 PM, Yann Sionneau <yann at minet.net <mailto:
>> yann at minet.net>> wrote:
>> Hi Daron,
>> Thanks for the commands, I would greatly appreciate a public git
>> repository with all that already set-up if it is so long and
>> bandwidth consuming to do.
>> So that I could git clone it.
>> Thanks !
>> Le 24/02/11 20:03, Daron Chabot a écrit :
>> On Thu, Feb 24, 2011 at 1:07 PM, Yann Sionneau <yann at minet.net
>> <mailto:yann at minet.net>
>> <mailto:yann at minet.net <mailto:yann at minet.net>>> wrote:
>> Hi Daron,
>> How did you do your git mirror of the CVS ? Is there any
>> tool to do
>> that ?
>> I simply used what git provides. See, "git help cvsimport".
>> The first step is doing a cvs checkout (HEAD will work):
>> 1) cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS co rtems
>> 2) mv rtems rtems.cvs
>> Then the commands I use to create my pristine, git-mirror of
>> the CVS
>> repo is:
>> 3) cd rtems.cvs
>> 4) git cvsimport -i -v -C ../rtems.mirror.git
>> !!!!!!!!!!!!!!! Beware: this will take *many* hours over the
>> network
>> i.e. do this at night (Alabama time) if you want to avoid
>> annoying repo
>> users/administrators.
>> I seem to recall this initially taking on the order of nine
>> hours. If
>> done locally, this operation is orders of magnitude faster
>> (wink, wink,
>> nudge, nudge Joel).
>> If people are interested, I may be able to put my
>> "rtems.mirror.git" in
>> a publicly accessible location to spare them the 10 hours of
>> suspense.
>> To update the git-mirror when the CVS repo changes, just
>> repeat 3) and
>> 4). This will take around 15 min over the network.
>> As recommended by the "git-cvsimport" man page, *do not* use the
>> git-mirror for working in. Do this:
>> 5) git clone rtems.mirror.git rtems.git # assuming
>> you want
>> these in same directory
>> Then, use the "rtems.git" repo to play around in...
>> FYI -- my "rtems.mirror.git" branches look like this:
>> (~/RTEMS/rtems.mirror.git)
>> djc at TooLBox--> git branch -a
>> B_beatnik_import_from_SLAC
>> B_rtems_mvme3100_bsp_slac
>> MOVED-ASM_H-TO-RTEMS-SUBDIR-4-6-branch
>> MOVED-FROM-C-SRC-EXEC-TO-CPUKIT-rtems-eng-200108xx
>> MOVED-FROM-C-SRC-TO-CPUKIT-rtems-4-5-branch
>> MOVED-FROM-LIBBSP-TO-LIBCHIP-rtems-4-6-branch
>> MOVED-FROM-SCORE-TO-RTEMS-rtems-4-6-branch
>> MOVED-FTPD-TO-CPUKIT-4-5-branch
>> MOVED-RTEMS_WEBSERVER-TO-CPUKIT-HTTPD-4-5-branch
>> MOVED-TO-LIBCPU-4-6-branch
>> MOVED-from-C-SRC-TO-CPUKIT-rtems-4-5-branch
>> MOVED-from-C-SRC-TO-CPUKIT-rtems-4-6-branch
>> OAR
>> SLAC
>> * master
>> origin
>> rtems-4-0-0-branch
>> rtems-4-10-branch
>> rtems-4-5-branch
>> rtems-4-6-branch
>> rtems-4-7-branch
>> rtems-4-8-branch
>> rtems-4-8-testing
>> rtems-4-9-branch
>> rtems-am-branch
>> rtems-eng-200108xx
>> rtemsdoc-4-5-branch
>> shttpd
>> zlib
>> "master" ---> HEAD, all the rtems-4-X-branches appear as in
>> the CVS
>> repo, and I really don't know (or care!) about the rest.
>> HTH.
>> -- dc
>> Did you just cvs checkout and then git init . && git add * ?
>> You had to keep the CVS related files into your git, in
>> order to be
>> able to to cvs up, right ?
>> Can you explain to me how to do like you ?
>> Thanks :)
>> Regards,
>> Yann
>> Le 24/02/11 16:34, Daron Chabot a écrit :
>> Hi Till,
>> I'm not sure if Yann is doing the same, but I've been
>> tracking
>> the RTEMS
>> cvs repos with git for some time and update it
>> semi-regularly
>> (doing an
>> update now). I maintain one git repo that is a "mirror"
>> of the
>> cvs repo,
>> and another git repo (clone of the mirror) for local
>> development
>> where I
>> "rebase" my work on top of the cvs HEAD.
>> You could do something similar, pulling Yann's
>> branch(es) into your
>> scratchpad repo...
>> Just a thought.
>> -- dc
>> On Thu, Feb 24, 2011 at 10:17 AM, Till Straumann
>> <strauman at slac.stanford.edu
>> <mailto:strauman at slac.stanford.edu>
>> <mailto:strauman at slac.stanford.edu>>
>> <mailto:strauman at slac.stanford.edu>>>> wrote:
>> On 02/24/2011 03:55 PM, Yann Sionneau wrote:
>> Le 24/02/11 14:40, Till Straumann a écrit :
>> On 02/24/2011 03:12 PM, Sebastien
>> Bourdeauducq wrote:
>> On Thu, 2011-02-24 at 11:13 +0000, Yann
>> Sionneau
>> wrote:
>> Feel free to merge these commits
>> with the
>> CVS, but
>> it will not be a
>> straight forward merge since my github
>> repository
>> has a lot of commit
>> that your CVS doesn't have. We are
>> out of sync.
>> Joel told me that the 4.11 release is
>> not before a
>> while. To reduce the
>> administrative overhead, and unless
>> someone sees
>> this as an
>> inconvenience, let's continue working
>> on this
>> BSP in the
>> Git repository
>> for now and I'll submit one big patch
>> before the
>> 4.11
>> release.
>> S.
>> Hmm - but I'd rather get only the BSP from
>> your git repo
>> and work with the main-line RTEMS otherwise.
>> How can I do that?
>> Thanks
>> Well you can checkout my git repo, it's a clone
>> of RTEMS
>> CVS of
>> when I
>> started the GSoC back in the middle of 2010.
>> Well - that's not exactly what I want. I want to stay
>> in-sync with
>> the current RTEMS development and use your latest BSP.
>> T.
>> Just check it out and you can play with RTEMS
>> and the
>> up-to-date
>> Milkymist BSP as if you were playing with RTEMS
>> CVS :)
>> The qemu to use is a special one (with milkymist
>> support) btw,
>> it's the
>> one from this git repo :
>> http://git.serverraum.org/?p=mw/qemu-lm32.git;a=summary
>> Link for how to compile lm32-qemu :
>> http://milkymist.org/wiki/index.php?title=Using_QEMU
>> Link for how to compile the BSP (but you sure
>> know how to do
>> that better
>> than me :)) :
>> http://milkymist.org/wiki/index.php?title=RTEMS_build_instructions
>> Link on how to run some tests :
>> http://milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
>> And eventually if you want to try flickernoise
>> (a GUI
>> application) :
>> http://milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
>> Have fun :)
>> rtems-users mailing list
>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>> <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>>
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20110224/8bf53da5/attachment-0001.html>
