RES: C Users Manual needs update
Fri Feb 25 13:35:25 UTC 2011
On 02/25/2011 06:17 AM, Fabrício de Novaes Kucinskis wrote:
> Hi Joel,
> Sorry, you're right, the new directives are in the document - I've wrote the
> e-mail while reading the manual and forgot to update the issue before
> sending, which is:
> The type 'rtems_clock_time_value' isn't available anymore on 4.10. So, it is
> not possible to call rtems_clock_get(RTEMS_CLOCK_GET_TIME_VALUE, ...).
> That's the item that needs updating.
Ohhh!  Can you file a PR on that?  Sounds like it needs to be fixed.
--joel
> Regards,
> Fabrício.
> -----Mensagem original-----
> De: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Enviada em: quinta-feira, 24 de fevereiro de 2011 19:33
> Para: Fabrício de Novaes Kucinskis
> Cc: rtems-users at rtems.com
> Assunto: Re: C Users Manual needs update
> On 02/24/2011 08:15 AM, Fabrício de Novaes Kucinskis wrote:
>> Hello,
>> I’ve noticed that the C Users Manual for RTEMS 4.10, on its item
>> ‘rtems_clock_get’, describes the old version of clock_get (RTEMS 4.8.1
>> and previous), that is not supported anymore. The new five or six
>> directives, that replace the old version, are not present on the document.
> The old version is still there just not recommended for new applications.
> I see the new smaller, more specific variants in the 4.10.0 docs online:
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.0/share/rtems/html/c
> _user/c_user00111.html
> What are you looking at where they are missing?
> --joel
>> Regards,
>> Fabrício de Novaes Kucinskis.
> rtems-users mailing list
> rtems-users at rtems.org
