Status of Networking Driver Milkymst One BSP
Cristian Paul Peñaranda Rojas
paul at kristianpaul.org
Sun Jan 23 00:48:20 UTC 2011
Hi Fallenou and rtems user list !,
Can you tell us a bit more of the status/know issues/TODO about the
Networking Driver for the Milkymist One BPS?.
I had been doing/following some basic tests of the rtems network capabillities,
mainlly following some info [1].But seems the wiki just point what really
works (tftpclient) because, so far i dint manage (lucky?) to stablish at least a
telnet/httpd TCP session :'(.
Surpriselly ICMP echo reply is ok, beside that s that the only trafic
i got from my M1 a running a telnet test is a Gratuitous ARP package
broadcasting the mac and ip of the device, but if i try both telnet or netcat against
a 23/80 tcp port i never pass from sending SYN and no reply from rtems IP.
Is this a problem related just with TCP part?, (i dint made UDP tests yet),
what can i do to help?, i just starting reading seriosly rtems docs,
today, but i really need serious support for TCP/IP comunication for my
project.
Anyway, i'll keep you posted in case i found something else
Saludos
Cristian Paul
[1] http://www.rtems.com/wiki/index.php/Milkymist
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20110122/146fbf28/attachment.bin>
