Network support with POSIX API
João Rasta freakforever at gmail.com
Mon Jan 3 18:49:44 UTC 2011
Thank you.
I'm not using RT tasks, but standard POSIX threads. Anyway, assuming i do
initialize both task and POSIX threads tables (because
rtems_bsdnet_initialize_network() initializes a RT task), i'll have both
POSIX_Init() and Init(). How are they managed?
Best,
JM
On Mon, Jan 3, 2011 at 5:44 PM, Eric Norum <wenorum at lbl.gov> wrote:
> You need to increase the number of tasks in the system.
> The error message is reporting the inability to start a network-related
> task -- and reporting that the failure was the result of trying to start too
> many tasks.
> On Jan 3, 2011, at 9:16 AM, João Rasta wrote:
> > Hi,
> > I'm using RTEMS with POSIX API and now i'm trying to setup the RTEMS
> network support in order to perform TCP/IP communications.
> > When i do:
> > rtems_bsdnet_initialize_network ()
> > I get the following error, happening in rtems_bsdnet_newproc() function
> of rtems_glue.c.
> > Can't create network daemon `ntwk': `too many'
> > fatal error, exiting
> > Is this a failure on rtems_task_create() because i'm using standard POSIX
> API? If so, is there a way to configure network support for POSIX API?
> > Best,
> > JM
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Eric Norum
> wenorum at lbl.gov
URL: <http://lists.rtems.org/pipermail/users/attachments/20110103/48104540/attachment-0001.html>
