Status of Networking Driver Milkymst One BSP
Cristian Paul Peñaranda Rojas
paul at kristianpaul.org
Tue Jan 25 04:20:23 UTC 2011
> for TCP tests you have the "milkymist_networking" test inside the
> testsuites/samples of my git repository.
Yes i'm aware of it
> You can find informations about how to run those tests (at least on
> Qemu) on this page : http://www.milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
I'm not usign Qemu atm, as i got a MM1 Board i'm working all on real
hardware, is this code just tested to work on qemu??
> You can do a telnet and get a RTEMS shell.
> I can find no reason why it wouldn't work on the board, so you can
> test those tests on the board too and let me know what happens :)
Sorry tell again. but my test was not sucefull
I flashed the board with the generated:
milkymist_networking.fbi
It booted ok as this log show:
*** MILKYMIST NETWORKING TEST by Yann Sionneau ***
== Initializing Network ==
== Add Route ==
Destination Gateway/Mask/Hw Flags Refs Use Expire
Interface
default 192.168.101.254 UGS 0 0 0
minimac0
192.168.101.0 255.255.255.0 U 0 0 1
minimac0
f92.168.101.254 UHSLt a r t i n g r t1e m s S h e l
l 0v i a t e l1n emtidn i-m-a cd0e
/a=u=l tS taacrctoiunngt tiesl nrettedm s= =w
no password
Device: /dev/pty0../dev/pty7 (8)pseudo-terminals
registered.
telnetd started with stacksize = 81920 and priority = 100
The conection is just made between my Laptop and the MM1 board.
The laptop ip is 192.168.101.2
You can check the graphical out from wireshark here [1] or get the
captured filed from here [2].
Resuming i always got a ARP package when the board boots ! (good)
I get ICMP reply if i ping it (we're close !)
But telnet, as you can see just SYN, no ACKs... and a later on my comand
line a Connection timed out.
Hope this helps !
I will be glad found that something is wrong, but is a shame i cant
telnet to the board yet :/.
Saludos
Cristian Paul
[1] http://kristianpaul.org/~paul/tmp/milkymist_networking.png
[2] http://kristianpaul.org/~paul/tmp/milkymist_networking
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20110124/37fd95b6/attachment-0001.bin>
