Issue with gettimeofday() in RTEMS 4.10;
Gedare Bloom
gedare at gwmail.gwu.edu
Fri Jan 28 14:33:21 UTC 2011
I wonder if this is this related to PR 1495?:
https://www.rtems.org/bugzilla/show_bug.cgi?id=1495
The symptom is similar, but I don't think the LEON3 has the same
structure of clock driver.
-Gedare
On Fri, Jan 28, 2011 at 9:11 AM, João Rasta <freakforever at gmail.com> wrote:
> Hi,
> I'm using gettimeofday() to profile a function. For this i do:
> struct timeval tim;
> // *Get actual clock
> gettimeofday(&tim, NULL);
> double t1=tim.tv_sec+(tim.tv_usec/1000000.0);
> // *GNC Calculations starting point
> Execute_gnc();
> // *Calculations termination point
> // *Calculate elapsed time with GNC calculations.
> double t2=tim.tv_sec+(tim.tv_usec/1000000.0);
> procDelay = (t2 - t1 + 0.0275);
> if (t1 > t2)
> printf(" WARNING %f > %f\n",t1,t2);
> else
> printf("%f\n",procDelay);
> But sometimes t1 is larger than t2, which should not be possible since t2 is
> allways measured after t1. For instance, the above code produces the
> following when this issue happens:
> WARNING 567996584.559981 > 567996584.550001
> The above code runs in loop and this happens roughly once in an hour (just
> an estimate). Is there any known overflow issue with the usec counter that i
> should be aware? RTEMS is running with a LEON-3.
> Best,
> JM
> rtems-users mailing list
> rtems-users at rtems.org
