[GSOC]Progress Report of MMU support project
Peter Dufault dufault at hda.com
Tue Jul 12 10:36:13 UTC 2011
On Jul 12, 2011, at 6:11 , Sebastian Huber wrote:
> I would not use size_t here since this is used for the size of single objects.
> I would use uintptr_t instead.
Isn't this memory range a single object?  It's mappable as a single object via the memory management hardware.
If you look at existing POSIX functions (mmap(), mprotect(), mlock()) the address is a void * and the size is a size_t.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
