ARM Interrupts
Manne Tallmarken mannet at kth.se
Wed Jul 13 18:50:22 UTC 2011
I guess PR stands for patch request... here it is:
Index: c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
--- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c      2011-07-13 16:34:37.000000000 +0200
+++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   2011-07-13 20:11:29.000000000 +0200
@@ -21,7 +21,7 @@
 void bsp_interrupt_dispatch(void)
-  rtems_vector_number vector = AIC_CTL_REG(AIC_ISR);
+  rtems_vector_number vector = AIC_CTL_REG(AIC_IVR);
   bsp_interrupt_handler_dispatch(vector);
@@ -44,6 +44,12 @@
 rtems_status_code bsp_interrupt_facility_initialize(void)
+  unsigned long i = 0;
+  for (i = 0; i < 32; ++i) {
+    AIC_SVR_REG(i<<2) = i;
   /* disable all interrupts */
   AIC_CTL_REG(AIC_IDCR) = 0xffffffff;
-Manne
________________________________________
Sent: Wednesday, July 13, 2011 20:23
To: Manne Tallmarken
Cc: Sebastian Huber; rtems-users at rtems.org
Subject: Re: ARM Interrupts
Manne, can you file a PR?
With the patch that works for you with 4.10.
Sebastian.. does this apply to the head as well?
This needs to be in 4.10.1
Thanks.
--joel
On 07/13/2011 01:12 PM, Manne Tallmarken wrote:
> The patch worked excellent, with one minor change: In the initialization routine, the for loop should set source vector registers on a four byte alignment.
> That is, change
> for (i = 0; i<  32; ++i) {
>    AIC_SVR_REG(i) = i;
> to
> Thanks for the patch. :-)
> -Manne
> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
> Sent: Wednesday, July 13, 2011 09:06
> To: rtems-users at rtems.org
> Can you please test this patch:
> --- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (revision 5018)
> +++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (working copy)
> @@ -21,7 +21,7 @@
> @@ -44,6 +44,12 @@
> +  for (i = 0; i<  32; ++i) {
> +    AIC_SVR_REG(i) = i;
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-users mailing list
Joel Sherrill, Ph.D.             Director of Research&  Development
