ARM Interrupts
Wed Jul 13 20:27:00 UTC 2011
Thanks.
PR1832 is now closed.
--joel
On 07/13/2011 02:10 PM, Joel Sherrill wrote:
> On 07/13/2011 01:50 PM, Manne Tallmarken wrote:
>> I guess PR stands for patch request... here it is:
> I never thought about PR=patch request.  I meant
> Problem Report in Bugzilla. :D
> All issues on releases need to have a tracking
> number.  Give http://bugzilla.rtems.org a try.
> File a new PR.  Write a description of the problem
> and attach the patch.
> We try to be very good at indicating which PRs are
> addressed by each minor number release on a branch.
>> Index: c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>> --- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c      2011-07-13 16:34:37.000000000 +0200
>> +++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   2011-07-13 20:11:29.000000000 +0200
>> @@ -21,7 +21,7 @@
>>    void bsp_interrupt_dispatch(void)
>> -  rtems_vector_number vector = AIC_CTL_REG(AIC_ISR);
>> +  rtems_vector_number vector = AIC_CTL_REG(AIC_IVR);
>>      bsp_interrupt_handler_dispatch(vector);
>> @@ -44,6 +44,12 @@
>>    rtems_status_code bsp_interrupt_facility_initialize(void)
>> +  unsigned long i = 0;
>> +  for (i = 0; i<   32; ++i) {
>> +    AIC_SVR_REG(i<<2) = i;
>>      /* disable all interrupts */
>>      AIC_CTL_REG(AIC_IDCR) = 0xffffffff;
>> -Manne
>> ________________________________________
>> From: Joel Sherrill [joel.sherrill at oarcorp.com]
>> Sent: Wednesday, July 13, 2011 20:23
>> To: Manne Tallmarken
>> Cc: Sebastian Huber; rtems-users at rtems.org
>> Subject: Re: ARM Interrupts
>> Manne, can you file a PR?
>> With the patch that works for you with 4.10.
>> Sebastian.. does this apply to the head as well?
>> This needs to be in 4.10.1
>> Thanks.
>> --joel
>> On 07/13/2011 01:12 PM, Manne Tallmarken wrote:
>>> The patch worked excellent, with one minor change: In the initialization routine, the for loop should set source vector registers on a four byte alignment.
>>> That is, change
>>>      AIC_SVR_REG(i) = i;
>>> to
>>> Thanks for the patch. :-)
>>> -Manne
>>> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
>>> Sent: Wednesday, July 13, 2011 09:06
>>> To: rtems-users at rtems.org
>>> Can you please test this patch:
>>> --- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (revision 5018)
>>> +++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (working copy)
>>> @@ -21,7 +21,7 @@
>>> @@ -44,6 +44,12 @@
>>> +    AIC_SVR_REG(i) = i;
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>> Phone   : +49 89 18 90 80 79-6
>>> Fax     : +49 89 18 90 80 79-9
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> rtems-users mailing list
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research&    Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>       Support Available             (256) 722-9985
