Example Application Compiling
Cláudio Silva claudiodcsilva at gmail.com
Thu Jul 14 09:33:33 UTC 2011
Hi,
I think it is better if you follow the getting started guide:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.0/share/rtems/html/started/started00024.html
The build should go something like this (assuming you are working on
/home/ahbi/):
cd rtems
export PATH=/opt/rtems-4.11/bin:$PATH
./bootstrap
cd ..
mkdir rtems_build
mkdir rtems_install
cd rtems_build
../rtems/configure --target=i386-rtems4.11 --enable-rtemsbsp=pc586 \
--enable-tests=samples --disable-posix --disable-itron \
--prefix=`/home/abhi/rtems_install`
make
make install
If all goes well rtems will be installed in /home/abhi/rtems_install.
Now to build the examples:
export RTEMS_MAKEFILE_PATH=/home/abhi/rtems_install/i386-rtems4.11/pc586
cd /home/abhi/
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P examples-v2
cd examples-v2
make
You can run the created executables on QEMU, Virtual Box, or in your PC:
http://www.rtems.com/wiki/index.php/QEMU
http://www.rtems.com/wiki/index.php/RTEMS_on_Virtualbox
Regarding the other questions:
- Yes. sparc-gdb includes a ERC32 simulator.
- /opt/rtems-4.11 contains your toolchain: i386-rtems4.11-gcc, etc
Cláudio Silva
On Thu, Jul 14, 2011 at 12:49 AM, Abhijit Nandy <abhijit.nandy at gmail.com> wrote:
> Hi,
> I have been trying to compile the example applications as given here :
> http://wiki.rtems.org/wiki/index.php/Example_Application_Compiling
> After I run in the current directory (/home/abhi), the following commands :
> cd rtems
> ./bootstrap
> cd ..
> mkdir pc586
> cd pc586
>  --prefix=`pwd`
> make
> I don’t get any directory like
> ${HOME}/WHERE_AM_I_BUILDING/pc586/i386-rtems4.10/c/pc586/testsuites/samples
> where the compiled samples are placed.
> I am expecting the samples directory to be in :
> /home/abhi/pc586/i386-rtems4.10/c/pc586/testsuites/samples
> All the previous steps right upto the end of the quick start page have
> finished perfectly. I am on Fedora 15 on Virtual box.
> Also I am a bit confused about how the programs meant for sparc are being
> run using GDB .
> Does the sparc-gdb program include a simulator for the sparc processor ?
> There is a rtems-4.11 folder in /opt/
> Is this the RTEMS simulator for sparc ?
> When the wiki says build tree, does it refer to the source code folder
> checked out from CVS at /home/abhi/rtems which has folders like automake, c,
> contrib, CVS etc ?
> Sorry for lots of questions, but I am a bit confused at the moment as to
> what goes where.
> I thought RTEMS would compile into a bootable image that would run in a
> virtual machine like qemu, like linux does.
> Thanks,
> Abhijit
> rtems-users mailing list
> rtems-users at rtems.org
