Failed paranoia test on leon2?
mike
antispam21 at verizon.net
Fri Jul 22 01:22:06 UTC 2011
Hi all,
Did anybody run paranoia on a leon2 with FPU? If not, do you use the function 'pow' on any hardware with FPU (not
software floating point)?
- I ran the 'paranoia' test in the RTEMS testsuites and ran it on a board with Atmel leon2 (AT697E) and saw that the
function 'pow(x,y)' failed. The
test was compiled with 'hard-float' (I use RTEMS 4.10, gcc 4.4.6 built from distribution. I have also tried Gaisler's
RTEMS 4.10 binaries with the same
failed results).
Testing powers Z^i for small Integers Z and i.
ERROR: Severity: DEFECT:computing
(2.00000000000000000e+00) ^ (3.00000000000000000e+00)
yielded 3.44895534024799920e+16;
which compared unequal to correct 8.00000000000000000e+00 ;
they differ by 3.44895534024799840e+16 .
Errors like this may invalidate financial calculations
involving interest rates.
Similar discrepancies have occurred 260 times.
Then I just compiled a simple app just calling pow(x,y) in a loop and the function failed with y > 2 (with x being any
value, as long as y>2 then it will give incorrect result).
Any comments/suggestions that I can try?
Thank you.
-mike-
URL: <http://lists.rtems.org/pipermail/users/attachments/20110721/a0186342/attachment.html>
