Rate monotonic help
Matthews, Lee l.matthews at imperial.ac.uk
Mon Jul 25 19:51:06 UTC 2011
Hi Joel,
Thanks for your reply. I set the clock tick using :
#define CONFIGURE_MICROSECONDS_PER_TICK 8195
Basically, I'm working on a digital filter and I need a function to execute every 8.195ms (or 122Hz), hence the above value.
I was indeed aiming for a tick to equal 1/122 of a second. Please excuse my noob question, but why do you think that that can't be right? By setting it to this value am I messing up the correct functioning of RTEMS?
Best wishes,
Lee
________________________________________
Sent: 25 July 2011 18:50
To: Matthews, Lee
Cc: 'rtems-users at rtems.org'
Subject: Re: Rate monotonic help
What is your clock tick configured as?  This is the
CONFIGURE_MICROSECONDS_PER_TICK configuration
parameter.
FWIW your code assumes that 1 tick == 1/122 of
a second from what I can tell and that can't be
right.
--joel
On 07/25/2011 12:44 PM, Matthews, Lee wrote:
> Hi
> I’m developing some software that uses RTEMS on an Aeroflex Gaisler
> LEON3 processor that is running on a Pender GR-CPCI-AX2000 development
> board.
> I’d like to setup a task that is called 122 times per second. I’m
> currently trying to use the rtems rate_monotonic functions but I’m not
> having much luck.
> I have used the example code from the rtems_user_guide as a guide.
> My function looks like the following :
> rtems_task Periodic_task()
>       rtems_name name;
>       rtems_id period;
>       rtems_status_code status;
>       unsigned int flag=0;
>       unsigned long count=0;
>       unsigned int i=0;
>       printf( "Starting periodic function : 61Hz clock output.\n");
>       printf( "Turning GPIO OFF.\n");
>       gpiolib_set(port1,1,0); // Set GPIO0 to OFF
>       for(count=0;count<1000000;count++) {}
>       printf( "Exiting wait loop.\n");
>       name = rtems_build_name( 'P', 'E', 'R', 'D' );
>       status = rtems_rate_monotonic_create( name, &period );
>       if ( status != RTEMS_SUCCESSFUL ) {
>             printf( "rtems_monotonic_create failed with status of
> %d.\n", status );
>             exit( 1 );
>       while ( 1 ) // RTEMS ticks per second set to 122.
>             if ( rtems_rate_monotonic_period( period, 1 ) ==
> RTEMS_TIMEOUT )  break;
>             /* Perform some periodic actions */
>             if(flag==0)
>                   gpiolib_set(port1,1,1); // Set GPIO0 to ON
>                   flag=1;
>             else
>                   flag=0;
>       /* missed period so delete period and SELF */
>       status = rtems_rate_monotonic_delete( period );
>             printf( "rate_monotonic_delete failed with status of
> %d.\n", status );
>             exit( 1 );
>       status = rtems_task_delete( RTEMS_SELF );
>       /* should not return */
>       printf( "rtems_task_delete returned with status of %d.\n", status );
>       exit(1);
> I’d like for the function to turn one of the GPIO lines on and off
> repeatedly, but all that seems to happen is that the code within the
> while ( 1 ) loop executes once, then stops.
> The code that I use to create and start this task is the following :
> Task_name1 = rtems_build_name( 'P', 'E', 'R', 'D' ); // Set task name
> to 'PERD'
>                 status = rtems_task_create(Task_name1, 1,
> RTEMS_MINIMUM_STACK_SIZE * 2,
> RTEMS_DEFAULT_MODES,RTEMS_DEFAULT_ATTRIBUTES, &Task_id1);
>                 if(status!=RTEMS_SUCCESSFUL)
>                                 printf("rtems_task_create unsuccesful\n");
>                                 exit( 0 ); // Exit
>                 else
>                                 printf("Created Periodic task\n");
>                 status = rtems_task_start( Task_id1, Periodic_task, 1
> ); // Start Periodic task
>                                 printf("rtems_task_start unsuccesful\n");
>                                 exit( 0 ); // Exit
> Could anyone shed some light on what I’m doing wrong please?
> Thanks in advance,
> Lee
Joel Sherrill, Ph.D.             Director of Research&  Development
