zlib build problem
Sebastien Bourdeauducq sebastien at milkymist.org
Sat Jul 30 10:43:30 UTC 2011
On Sat, 2011-07-30 at 12:30 +0200, Ralf Corsepius wrote:
> What I also do not understand is you telling us to be using the rpms
> and at the same time telling us to be recompiling.
I was just making sure that I had the patches from CVS head correctly
applied. Was that not the right thing to do?
> I'd guess you either have some broken customisations applied or you
> are not "rebuilding" correctly.
Install toolchain RPMs, fetch CVS head, and then this causes the issue
for me:
./bootstrap -p
./bootstrap
cd ..; mkdir build_rtems; cd build_rtems
 ../rtems/configure --target=lm32-rtems4.11 --enable-rtemsbsp=lm32_evr
--enable-posix --disable-itron --enable-networking
--disable-multiprocessing --disable-tests --prefix=/opt/rtems-4.11
make
I have autoconf (GNU Autoconf) 2.68 and automake (GNU automake) 1.11.1.
Is that anything wrong with this way of rebuilding?
I'm not writing those emails just to bother you, Ralf.
> P.S.: Please fix your mail server - I am receiving an absurd "out of
> office/I am sick" mail in response to mails to you.
I have no such auto-responder set up and you are the first person
telling me about it, even though I receive dozens of emails a day on
this address. Can you forward me such an email you received, including
headers?
