ARM Interrupts
Gedare Bloom gedare at gwmail.gwu.edu
Sun Jul 10 18:32:55 UTC 2011
You probably want to copy from an ARM-based board instead of the
no_cpu template. You have the right interpretation of set_vector: it
just sets the jump in the interrupt table directly to the handler, as
opposed to vectoring through RTEMS interrupt handling (which supports
nesting interrupts and creates an environment to execute C code).
I don't use the ARM cpus much, so I cannot speak to what does or
doesn't work, or rather how the ARM BSPs install ISRs.
-Gedare
On Sun, Jul 10, 2011 at 2:06 PM, Manne Tallmarken <mannet at kth.se> wrote:
> Hello people,
> First of all, I am pretty new to RTEMS and currently I am working with BSP development to a board (kb9202) with an at91rm9200 cpu.
> What I need to get working is the clock driver and I feel a bit lost in where to add the code to get it nice. My approach is the following:
> Copy and modify the code from no_bsp/clock/ckinit.c
> Now, that file makes a call to set_vector
> => need to write that function
> Copy and modify the code from no_bsp/startup/setvec.c
> Now, I need to install non-RTEMS ISRs as "raw" interrupts  (my interpretation of "raw" interrupts is putting pointers in the interrupt controller inside the uC)
> => seems like the RTEMS-way of doing this is to call _CPU_ISR_install_raw_handler, but that function does not exist for the arm
> => need to add that function to rtems-4.10.0/cpukit/score/cpu/arm/cpu.c.
> When looking in cpukit/score/cpu/no_cpu/cpu.c, _CPU_ISR_install_vector makes a call to _CPU_ISR_install_raw_handler so maybe I need to add that call to the arm file as well (but then I don't know if I need to do more modifications).
> But wait! Now it's not BSP-development anymore, it's about porting basic functions to the ARM cpu.
> Have I missed something?
> What is the correct way of adding a clock tick driver for this cpu?
> Regards,
> Manne
> rtems-users mailing list
> rtems-users at rtems.org
