ARM Interrupts
Manne Tallmarken
mannet at kth.se
Wed Jul 13 18:12:55 UTC 2011
The patch worked excellent, with one minor change: In the initialization routine, the for loop should set source vector registers on a four byte alignment.
That is, change
for (i = 0; i < 32; ++i) {
AIC_SVR_REG(i) = i;
to
AIC_SVR_REG(i<<2) = i;
Thanks for the patch. :-)
-Manne
________________________________________
From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
Sent: Wednesday, July 13, 2011 09:06
To: rtems-users at rtems.org
Subject: Re: ARM Interrupts
Can you please test this patch:
Index: c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
--- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (revision 5018)
+++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (working copy)
@@ -21,7 +21,7 @@
void bsp_interrupt_dispatch(void)
- rtems_vector_number vector = AIC_CTL_REG(AIC_ISR);
+ rtems_vector_number vector = AIC_CTL_REG(AIC_IVR);
bsp_interrupt_handler_dispatch(vector);
@@ -44,6 +44,12 @@
rtems_status_code bsp_interrupt_facility_initialize(void)
+ unsigned long i = 0;
+ for (i = 0; i < 32; ++i) {
+ AIC_SVR_REG(i) = i;
/* disable all interrupts */
AIC_CTL_REG(AIC_IDCR) = 0xffffffff;
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
