ARM Interrupts
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Jul 13 19:10:03 UTC 2011
On 07/13/2011 01:50 PM, Manne Tallmarken wrote:
> I guess PR stands for patch request... here it is:
I never thought about PR=patch request.  I meant
Problem Report in Bugzilla. :D
All issues on releases need to have a tracking
number.  Give http://bugzilla.rtems.org a try.
File a new PR.  Write a description of the problem
and attach the patch.
We try to be very good at indicating which PRs are
addressed by each minor number release on a branch.
> Index: c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
> --- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c      2011-07-13 16:34:37.000000000 +0200
> +++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   2011-07-13 20:11:29.000000000 +0200
> @@ -21,7 +21,7 @@
>   void bsp_interrupt_dispatch(void)
> -  rtems_vector_number vector = AIC_CTL_REG(AIC_ISR);
> +  rtems_vector_number vector = AIC_CTL_REG(AIC_IVR);
>     bsp_interrupt_handler_dispatch(vector);
> @@ -44,6 +44,12 @@
>   rtems_status_code bsp_interrupt_facility_initialize(void)
> +  unsigned long i = 0;
> +  for (i = 0; i<  32; ++i) {
> +    AIC_SVR_REG(i<<2) = i;
>     /* disable all interrupts */
>     AIC_CTL_REG(AIC_IDCR) = 0xffffffff;
> -Manne
> ________________________________________
> From: Joel Sherrill [joel.sherrill at oarcorp.com]
> Sent: Wednesday, July 13, 2011 20:23
> To: Manne Tallmarken
> Cc: Sebastian Huber; rtems-users at rtems.org
> Subject: Re: ARM Interrupts
> Manne, can you file a PR?
> With the patch that works for you with 4.10.
> Sebastian.. does this apply to the head as well?
> This needs to be in 4.10.1
> Thanks.
> --joel
> On 07/13/2011 01:12 PM, Manne Tallmarken wrote:
>> The patch worked excellent, with one minor change: In the initialization routine, the for loop should set source vector registers on a four byte alignment.
>> That is, change
>>     AIC_SVR_REG(i) = i;
>> to
>> Thanks for the patch. :-)
>> -Manne
>> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
>> Sent: Wednesday, July 13, 2011 09:06
>> To: rtems-users at rtems.org
>> Can you please test this patch:
>> --- c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (revision 5018)
>> +++ c/src/lib/libcpu/arm/at91rm9200/irq/irq.c   (working copy)
>> @@ -21,7 +21,7 @@
>> @@ -44,6 +44,12 @@
>> +    AIC_SVR_REG(i) = i;
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>      Support Available             (256) 722-9985
