adjtime()
    Till Straumann
    strauman at slac.stanford.edu
    Thu Jun  2 02:02:56 UTC 2011
Currently, adjtime() basically steps the time (albeit not
backwards if IRC) and this only if the requested difference
is bigger than a full clock tick.
IMO it would make sense to improve this implementation by
- gradually adjusting the clock, i.e., absorbing the requested
   delta over multiple clock ticks.
- allow small adjustments (especially on architectures
   with a high-resolution clock)
I know that adjtime() is not posix but AFAIK there is nothing else.
Ultimate goal would be letting an NTP client use adjtime().
Maybe even a better idea would be incorporating the Mills
algorithm into the system clock and add adjtimex() for tuning
it with an NTP client.
RFC
- Till
