interrupt never occur on psim ?
quanming shi
shiquanming10 at gmail.com
Thu Jun 9 15:42:54 UTC 2011
I got a problem about the DSI exception handle, with the psim environment.
the function mmu_handle_dsi_exception has been set like this , in
Bspstart.c:
* BSP_rtems_irq_mng_init(0);
ppc_exc_set_handler(ASM_PROT_VECTOR,
mmu_handle_dsi_exception);*
and MSR printed in my testcase is 0xa072, as expected, IP, IR, DR bit have
been set to 1
My problem now is the exception handle never work. when I try your test
case , the test did not end with the interrupt
As expected, the test case should end like this(break by GDB):
Breakpoint 1, C_exception_handler (excPtr=0x4d4c8)
at ../../../../../../../rtems/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors_init.c:112
112 int recoverable = 0;
but my situation is :
*** MMU ALUT TEST ENDS ***
Program exited normally.
Does this mean the exception setting failed?
consider I already flushed tlb with tlbia instruction and write dummy
entries into PTEG , I suppose the DSI interrupt should occur, right?
I appreciate any tips about the reason cause the kind of problems.
Such as some config about psim or rtems I need to know , or any other
ideas
thank you
Best regards
Quanming Shi
URL: <http://lists.rtems.org/pipermail/users/attachments/20110609/8d6ca875/attachment.html>
