Executing samle RTEMS application on QEMU
S Akhtar
crystaldoll85 at gmail.com
Mon Jun 20 06:37:35 UTC 2011
It seems like no one knows solution to my problem...
On Fri, Jun 17, 2011 at 8:55 AM, S Akhtar <crystaldoll85 at gmail.com> wrote:
> Dear RTEMS users
> I am using RTEMS-4.10 for i386ex board
> I have installed toolchain and RTEMS with i386ex bsp and set up appropriate
> PATH and RTEMS_MAKEFILE_PATH variables
> I am using windows xp
> But when i execute sample application hello.exe on qemu, i get the
> following error
> qemu: fatal: Trying to execute code outside RAM or ROM at 0xff0720ff
> EAX=00000001 EBX=f000e2c3 ECX=03f98dfe EDX=000020ff
> ESI=0007fdc8 EDI=00000001 EBP=0007fd9c ESP=0007fd40
> EIP=ff0720ff EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0
> ES =0010 00000000 ffffffff 00cf9300 DPL=0 DS [-WA]
> CS =0008 00000000 ffffffff 00cf9a00 DPL=0 CS32 [-R-]
> SS =0010 00000000 ffffffff 00cf9300 DPL=0 DS [-WA]
> DS =0010 00000000 ffffffff 00cf9300 DPL=0 DS [-WA]
> FS =0010 00000000 ffffffff 00cf9300 DPL=0 DS [-WA]
> GS =0010 00000000 ffffffff 00cf9300 DPL=0 DS [-WA]
> LDT=0000 00000000 0000ffff 00008200 DPL=0 LDT
> TR =0000 00000000 0000ffff 00008b00 DPL=0 TSS32-busy
> GDT= 0000833c 00000027
> IDT= 00000000 000003ff
> CR0=00000011 CR2=00000000 CR3=00000000 CR4=00000000
> DR0=00000000 DR1=00000000 DR2=00000000 DR3=00000000
> DR6=ffff0ff0 DR7=00000400
> CCS=00000400 CCD=fffffc01 CCO=SUBL
> EFER=0000000000000000
> FCW=037f FSW=0000 [ST=0] FTW=00 MXCSR=00001f80
> FPR0=0000000000000000 0000 FPR1=0000000000000000 0000
> FPR2=0000000000000000 0000 FPR3=0000000000000000 0000
> FPR4=0000000000000000 0000 FPR5=0000000000000000 0000
> FPR6=0000000000000000 0000 FPR7=0000000000000000 0000
> XMM00=00000000000000000000000000000000
> XMM01=00000000000000000000000000000000
> XMM02=00000000000000000000000000000000
> XMM03=00000000000000000000000000000000
> XMM04=00000000000000000000000000000000
> XMM05=00000000000000000000000000000000
> XMM06=00000000000000000000000000000000
> XMM07=00000000000000000000000000000000
> This application has requested the Runtime to terminate it in an unusual
> way.
> Please contact the application's support team for more information.
> the qemu command i use is
> qemu -L . -m256 -boot a -fda rtems-boot.img -hda fat:. -no-reboot -kernel
> hello.exe
> the grub window appears and i type:
> set root=(hd0,1)
> multiboot (hd0,1)/hello.exe
> boot
> then i get the error mentioned above
> i am using qemu 0.13.0-windows
> Regards
> S. Akhtar
URL: <http://lists.rtems.org/pipermail/users/attachments/20110620/d1f57afc/attachment.html>
